Turn signal and brake lights
Discussion in 'Ask An Owner Operator' started by Thotphobia, Jan 11, 2022.
  1. Thotphobia
    Thotphobia Light Load Member
    69
    47
    Apr 21, 2021
    Hello there drivers, my trucks left turn signal works for like 2 seconds then cuts off, and also I have no truck and trailer brakes along with it. I was told it’s under the brake pedal, could it be something else? Like the relay? I already checked the fuses and they’re all good.
    NYStarcar and clausland Thank this.
  3. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Sounds like a bad ground going on. Also, have you gone from incandescent to LED lighting by chance?
  4. Thotphobia
    69
    47
    Apr 21, 2021
    Nah haven’t done anything to it. Just stopped out of nowhere. I drive a 90 pete
  5. bad-luck
    bad-luck Road Train Member
    3,300
    6,064
    Nov 16, 2013
    Baltimore, Maryland
    Try replacing the flasher, for your turn signals. Also check the relays for the brake lights.
