turn signal/fasher problems
Discussion in 'Volvo Forum' started by Lamppa, Feb 18, 2013.
  1. Lamppa
    Lamppa Bobtail Member
    17
    5
    Feb 4, 2013
    Fargo, ND
    So here is my first request for some help. Thank goodness Ifound this place for some support!
    2000 VN model (I think)
    The turn signals work in all places
    The flasher only works in the rear. None of thd front turn signals work, the taillights do.
    When you turm on the flasher, the flasher clicks, the rear lights flash but that's all.
    I swapped the flasher with another, same problem.
    There are 2 fuses, one left and one right turn signal fuse. When the turnw are on, there is power at the fuses.
    When the flasher is on, there is no power at the fuses for left and right.
    There is power on both sides of the flasher fuse.
    Dealer says its the flasher, but that's silly and I tried one from a truck that works fine and that's not it.
    Any ideas?
  3. tirednaz
    tirednaz Heavy Load Member
    838
    430
    Oct 4, 2011
    Arizona
    Are you getting power to the bulb sockets? If not trace it back from there. The wiring harness should come together on the left or right side and then split off from there to the other side. Look for the quick disconnect for the harness and make sure you have a good connection no corrosion broken ends etc.
  4. Lamppa
    17
    5
    Feb 4, 2013
    Fargo, ND
    Couldnt figure it out, sent to dealer.
    Will post repair later.
