Turn Signal Issue on 1980 359 Pete
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lancair, Apr 17, 2025.
  1. Lancair
    Lancair Bobtail Member
    Apr 17, 2025
    I have an issue where after starting the truck the red light on the center of the signal stat is on (red). After the first use of the turn signal, left or right when I return the signal handle to center the flasher keeps flashing and the red light in the center of the signal stat flashes. I recently replaced both the turn signal wiring harness and signal stat (comes plug and play from Dirks) and the headlight/turn signal/parking light harness from the cab to the hood. This issue pre-existed the new harnesses. The harness to the tail lights has been disconnected for debugging. The trailer wiring harness has also been disconnected. I even tried disconnecting the headlight/turn/parking harness to the hood. I also disconnected the brake light switch on the air manifold. The turn signal light indicators on the dash work as expected as do the green signal lights on the signal stat switch. Thoughts?
  3. SmallPackage
    5,702
    18,226
    Dec 20, 2019
    Marion Texas
    When the red light for the 4 ways flash on the signal stat does the 4 ways on the truck flash with it? Are you using a 3 prong flasher or 2 prong? They need a 3 to function correctly.
  4. Lancair
    Apr 17, 2025
    Yes, the 4-ways do work when engaged even when the flasher is flashing without being invoked. The new signal stat harness has a 3 prong flasher.
    Rideandrepair Thanks this.
  5. SmallPackage
    5,702
    18,226
    Dec 20, 2019
    Marion Texas
    I now you said the switch is new but the symptoms you discribe in my experiences with those is either the contact plate inside is shorted because of the solder connections for the wires are running together or there is grease,oil,or some other liquid inside on the plate causing s short. Take apart and check that.
    On the 3 prong flasher make sure fused key off hot all the time 12v is one. The second one goes to the switch for the turns signals on truck and the third is just a “pilot”signal for the indicator lights on switch to flash.
  6. Lancair
    Apr 17, 2025
    Thanks for the tip. I will pull it apart can check the connections. Not sure if Dirks builds these in their shop or they buy them, but I will also call them on it. Note: this was also an issue with previous signal stat switch which makes me think it´s something else.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    Google: Signal - Stat 900 trouble shooting guide. It is out there somewhere.
  8. wore out
    wore out Numbered Classic
    16,760
    205,123
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Very possible you have a bulb shorted together but by unhooking all the harness you have eliminated that.
