Turn signal stalk unit KW W900
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hanadarko, Sep 22, 2010.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    My turn signal lever switch doesnt like to always work on LEFT turns. If you crank on it (pull it down hard to the lower left) then it starts working.
    So, I figured I would replace it. Can I do this w/o taking off the steering wheel, and if so, how? - The plastic collar doesnt seem to come off yet it only looks like a simple 2 piece thingy...
  3. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    Is it the standard Grote switch? Maybe a picture would help.
    The Grote ones just bolt or screw on a bracket welded to the column. The plug on our Freighliner had a retaining screw too.
    Bill
  4. QUALITYTRUCK
    1,809
    1,770
    Jun 14, 2009
    romulus,mi
    sorry!you have to remove the wheel.harbor freight sells a cheap puller set for like $20.so do the major parts stores.very easy to do considering no air bag.good luck.
  5. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    Dam, I had thought it could be done w/o pulling the wheel. Of course thats what Toyota said had to be done and I did it w/o pulling the wheel...
  6. grizzly
    grizzly Medium Load Member
    599
    432
    Aug 27, 2008
    Layton, Ut
    I just replaced mine, and yes you have to pull the steering wheel. The part from KW is about $100. Also make sure you don't break the plastic guard under the steering wheel, it's $75 from KW. :biggrin_25513:
    tommygun58 Thanks this.
  7. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    I got a price of $47 on this part...Hmm. Maybe they only quoted me the plastic arm!!!
    PS. I am sure I will break the plastic guard. I have that luck :biggrin_25524:
  8. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    It seems this is a common problem with KW, mine has it too, but is the right turn that don't work.
  9. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Depending on what your steering column looks like you may or may not have to pull it. I have an '01 that had the old dash and it required wheel removal but the '02 and up doesn't (newer dash design). If you do pull the wheel make sure you put it on straight or it will annoy the hell out of you, ask me how I know this! :biggrin_25523:
  10. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    oh hell, its crooked as it is. Once I get the kingpins done and aligned, then I will fix the steer ahead. The wheel is like 7 and 2 right now.
    papa1953 Thanks this.
  11. tommygun58
    tommygun58 Light Load Member
    88
    61
    Sep 22, 2015
    East Texas
