Turn Signals and Hazards Fast Flash
Discussion in 'Peterbilt Forum' started by SoTexCoyote, Feb 24, 2011.
  1. SoTexCoyote
    SoTexCoyote Bobtail Member
    20
    12
    Jun 25, 2010
    San Antonio, Texas
    Need some help guys, truck is a 99 377, turn signals and hazards fast flash when activated. All bulbs are good, I'm stumped.
    Any help will be greatly appreciated,
    Carl
  3. jaysolomon
    jaysolomon Light Load Member
    78
    7
    Sep 17, 2010
    tried new flasher? check all grounds
    SoTexCoyote Thanks this.
  4. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Exactly right....flasher unit is about to give up the last "phlash"!
  5. SoTexCoyote
    20
    12
    Jun 25, 2010
    San Antonio, Texas
    Thanks guys, will check, change the flasher.
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    Don't know about on a Pete, but in a Volvo the flasher sounds like it is flashing fast when you have a burned out bulb anywhere, but when you watch the lights they are flashing at normal spped. I had one bulb that had a loose base, and would work intermittently, drove me nuts.
  7. SoTexCoyote
    20
    12
    Jun 25, 2010
    San Antonio, Texas
    Thanks everyone, replaced the flasher with a new Grote 20 lamp flasher. Also found a problem with the ground on the right front turn signal lamp. Everything works good now.
    Carl
    otherhalftw Thanks this.
  8. The Truckist
    The Truckist Medium Load Member
    342
    245
    Sep 11, 2010
    Hey Coyote, I don't imagine you just changed over to LED lights/bulbs, did you? Probably not or you would have mentioned it but that would require a specific flasher or a little wiring ingenuity. Just a thought...
