turn signals & clearance lights problem
Discussion in 'Freightliner Forum' started by raphaelkg, Mar 14, 2015.
  1. raphaelkg
    raphaelkg Bobtail Member
    I have a 07 freightliner columbia with turn signal lights and clearance lights problem. When truck has the turn signal on either way they work fine and turning on the headlights turn signal light stop working they stay on outside of truck and inside the dash and when u turn off head lights and just leave the clearance lights all the light on truck start flashing
  3. brian991219
    brian991219 Road Train Member
    2,999
    6,092
    Aug 10, 2013
    Lords Valley, PA
    Does it do it without a trailer attached? If yes then the problem is in the truck, if it only does it with the trailer attached then the problem is in either the trailer or the 7 wire cord, plug, or socket. It sounds like you have a weak ground or a short between the turn signal and marker light circuit. Check the 7 wire plug for corrosion or a bent/broken pin, check your tail lights for corrosion or broken wire, maybe even an internal short in one of the tail light bulbs. Also check your front turn signal/marker light wires for corrosion, short, or broken wires.
  4. Dave 1960
    Dave 1960 Road Train Member
    4,021
    1,486
    Mar 1, 2010
    Shepherd, TX
    In my 06 Century Poor ### Management truck I had to work on the wiring on both front corners. I would say it's a Freightshaker thing.
  5. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Does it have fuse for DRL? Try taking that out.
