Turn up CAT 3406E
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gregrob, Sep 28, 2010.
  1. gregrob
    gregrob Bobtail Member
    11
    Sep 28, 2010
    Cheyenne, WY
    Hi guys,
    I'm getting a 96 Volvo with a cat 3406.
    Here's the deal, the door tag says 375hp is what its rated right now.
    The valve cover sticker says 410hp advertised, right beside that it also says Max hp 550
    My question is, how far can I turn this engine up, and what do I need to do so.
    I plan on doing the boost and fuel temp mod as soon as I get a chance. Making the wires myself from radio shack.
    I want to get the injector trim codes put in it to turn it up as much as I can, or buy a used ECM that has them in it.
    Can anyone help?
    Thanks,
    Greg
  3. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    PM Mr. Haney...
  4. gregrob
    11
    Sep 28, 2010
    Cheyenne, WY
    Ok will do. I've read some of his posts via searching.
    Thanks
  5. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    You'll need the complete engine serial number listed on the tag at the valve cover. It should start with 5EK or possibly 6TS depending on when it was built. This engine should have started life as a 410 Hp raitng. The problem with this is the lower hp rating CAT's with these serial numbers are limited to how much you can do with them, because of the internal parts to build them.
    I'll send you a PM
    gregrob Thanks this.
  6. cdustercc
    cdustercc Bobtail Member
    Hertford, NC
    I would also like to turn up a 3406E. Could Mr. Haney send me a PM as well?
    Thanks,
    Craig
  7. Mr. Haney
    2,693
    2,041
    Dec 17, 2008
    I sent you a personal message
  8. ShomotionDenver
    ShomotionDenver Bobtail Member
    I'm hoping Mr. Haney can provide some insight. I recently purchased a 1999 Peterbilt 379EXH with a blown 3406E (Serial # 2WS / 70 Pin). Is this engine interchangeable with an early model C15 ? Would it require any major wiring or would it basically be plug and play? Are there any serial #'s I should look for in the early model C15.
    Regards,
    Mike
  9. power freak
    power freak Light Load Member
    220
    60
    Apr 23, 2009
    A c15 will hook right up to your wiring you may have to change some parameters in the ecm for tach cal man fan overide switch and the such.I would look for a 6nz 455 or above The 435 and lower require alot of hard part changes to get higher power levels out of them.
  10. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    A 2WS, 6NZ, 7CZ, 1MM should all be a straight swap if you get the ecms with them.
  11. Mr. Haney
    2,693
    2,041
    Dec 17, 2008
    It's a plug and play with the C-15/6NZ, C-16/7CZ, 3406E/1MM, 3406E/2WS and the famous bridge C-15/MBN
