I'm new to fuel transportation. How can I make a right turn with tanker in the intersection with tandem all the way back.
Turning right with fuel tanker
Discussion in 'Experienced Truckers' Advice' started by darkyoung, Dec 2, 2023.
Page 1 of 6
Don't tell -- let me guess -- you're pretty new to driving ANY big rig -- and not just fuel, right?
Watch the following video:
Turns in a big rig
-- Lbrian991219, aussiejosh, tscottme and 1 other person Thank this. -
brian991219, aussiejosh, Sons Hero and 6 others Thank this.
Slide the tandems up…
Let us know how that works for you.Crude Truckin', mitmaks, buzzarddriver and 3 others Thank this. -
Bud A., aussiejosh, snowwy and 4 others Thank this.
I’m going to assume you’re new to trucking and to gas for my explanation.
The factors are many, but I’ll cover basic ways that i use.
If traffic is a problem, and you can’t use the oncoming turn lane, then split the lanes as you approach the turn. Go as far as you can before bending it and spin that steering wheel like you stole it to gain as much real estate for your tandems as possible, and be as close to the oncoming cars as you dare. Go very slowly so you can correct before you have a problem.
I have two intersections that are extremely tight that i frequent, and this is the best solution I’ve come up with.
The hard part is cars over the stop line stealing real estate from your turn radius.
More than once I’ve watched that driver of the car freak out when i bend my tractor and pass within inches of their front bumper.
Funny thing is i make those two turns a couple times a week, and have for the past couple years. I’ve got the geometry down pretty solid. Only once have i had to stop and back slightly to bend it tighter to make the turn without curbing the snot out of it.
Second option is 3 left turns, if possible. Go past your desired intersection, take the next left, then another left, and the 3rd left puts you on the lane to enter that place where you wanted to turn in the first place.
Or figure out how to come from the opposite direction so you have a left turn instead of right turn.
Again, so many factors apply here that it’s difficult to address them all.
If you have a satellite image of that intersection, i can try and be more specific on how i would do it.
Hauling gas, you sometimes need to be very creative on routing and approach to your drops.
Yes, people will be irritated and play chicken with you, but just wave and smile. They always move.
I have entered the store via the exit lane, i have called ahead to have them block pumps off, and I’ve used my cones to block off access so i could properly position my truck to drop.
My line of thought is, how can i do this as safely and smoothly as possible? What do i need to achieve this? In the grand scheme, I’m only there at the station for 45 minutes max. The delivery I’m putting in will cover them for hours.
It’s a minor inconvenience to their customers for me to be in there to drop the fuel they’ll want all day.
On routing, i pull gps directions and go through the entire route, and identify those areas i think will be a problem.
I come up with a base plan in my head, how to approach, what I’m looking for to turn safely, and find secondary options if I’m blocked or it looks too tight to pull it safely.
Most stores i know by heart. New stores I’ll call another driver that’s done it, or I’ll do my satellite image process to figure it out before i leave the rack.
You get no points for screwing up.
Having a plan before you roll and then executing it smartly is a hallmark of a gas hauler.Last edited: Dec 2, 2023
Chicken wang, tarheelsfan105, Lav-25 and 5 others Thank this. -
People do turns like that every day, and have for decades. Why are you wasting our time???
Rubber duck kw Thanks this. -
Lav-25 Thanks this.
Page 1 of 6
