Tutorials on mounting double hump fenders?
Discussion in 'Questions From New Drivers' started by JoeF2002, Jun 24, 2016.
  1. JoeF2002
    JoeF2002 Light Load Member
    165
    119
    Dec 31, 2015
    Saylorsburg, PA
    Hey gang - anyone know of any videos or tutorials online that provide instructions on how to mount double hump fenders? I got a sent + mounting brackets from Talladega. No instructions though. And when I called they said they don't have anything.
    Any suggestions on where I can go to get up to speed on mounting these things?
  3. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    It will take two days at least. No two trucks are ever the same. Measure twice drill once. Use at a minimum of 1 2x4 between the tires and the fender wit the suspension down, for clearance. You may be able to start at the quarter fender mounting location.
    I know at times they are necessary, but fenders are a pain. Especially double humps. When doing brakes or a wheel seal you are working in what seems like a culvert, and you will try to stand up at least once. While in the culvert.
    JoeF2002 Thanks this.
  4. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    Some of the plastic double hump fenders can be quickly removed off the mounting posts by loosening allen screws. All I will add is try and use existing holes in frame by cutting huck bolts with cutting torch and chiseling the bolt out of the frame rather then drilling new 5/8 holes through double frame. If drilling is only option renting a mag drill will save your wrists and a whole lot of time.
