TV for mid roof 70" cascadia
Discussion in 'Questions From New Drivers' started by 77fib77, Mar 10, 2019.
  1. 77fib77
    77fib77 Road Train Member
    10,570
    66,376
    Jul 7, 2010
    St Louis
    What size tv can I get in it? . 34" or 40"? Is 40 too big? Is mounting to the tv mount by drilling into the cabinet wall a fine thing to do?
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I got a 55" I put up on the back wall with lag bolts and just siliconed the ends that stick out. So far no leaks.
    77fib77 Thanks this.
  4. PE_T
    PE_T Road Train Member
    I’ve always thought about mounting it to a thick sheet of wood you can get from Home Depot. Lean the sheet of wood on a side of the truck. Then use rope and bungie cords to keep it upright and stable. I remember having a folding bicycle stored in the top bunk, upright, and held with ropes and bungie cords. I never had an issue, even when braking hard.
  5. Spar26
    Spar26 Bobtail Member
    5
    Im in a freighliner classic xl., I know the mid roof sits a little lower but this may still work as well. I dont like the idea of mounting with regular screws as with vibration screws can back out. I have a 42" mounted to the storage compartment that folds and rotates behind the passenger seat when not in use. So its one of those mounts that folds out and rotates. . I mounted the mount to the front of the storage cabinet. So that when folded out I can watch from the bunk laying down. I will try to send you a picture if your intrested.
  6. Espressolane
    17,539
    107,434
    40 inch screen seems like it would be to big for the space.
