TV / Laptop charge Inverter
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by dg37663, Mar 25, 2014.
  1. dg37663
    dg37663 Bobtail Member
    40
    7
    Dec 16, 2013
    Pasadena, TX
    I am wanting to run a TV and charge my laptop on an inverter. Is it possible to accomplish this on one of those plug in the 12v types? The TV is small. A 19" and the laptop is a standard dell.
    Thanks,
    Dave
  3. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    You have to know the combined wattage, then to know not the maximum wattage (surge), but the run wattage of the inverter. The inverter might say 1500 watt yet reality it only cranks out 1100 watts. The laptop would be better off with a 12 volt adapter frome some one like Radio Shack. I bought one for my HP and it was only $15 IIRC.
  4. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    A 19" TV is going to use about max 160 watts so yes a plugin inverter should work, together with charging your laptop. In my experience though, the power from the inverter seemed to charge the laptop batteries a lot slower, than using the power at home. But YMMV.
    Good luck
  5. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    I used a 12v for my lap top,portable dvd player and cell phone worked fine but my hd tv it blew a fuse and it was a small tv.
  6. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Too dang noisy
    They have TVs that plug into the socket if that's all you want.
    The box on my charging cable got extremely hot using a DC to ac box. Better to just get the big one.
    Like that guy said fuses will blow if you use the outlet.
  7. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    It will work ok, until you shut the Truck off.
    If you're going to go work for a company, be careful hard wiring inverters. Most don't want you doing it.
    lovesthedrive Thanks this.
