Twin Stick Transmissions and Modern Powerplants
Discussion in 'Experienced Truckers' Advice' started by jldilley, Sep 11, 2022.
  1. jldilley
    jldilley Medium Load Member
    485
    406
    Oct 13, 2013
    Indianapolis, In
    A question for all of the old school truckers (and old school at heart): do you have any experience with twin stick transmissions or auxiliary boxes hooked to modern power plants? I’ve been told by experienced drivers that installing, for example, a 5x4 Spicer behind a modern engine would destroy the auxiliary box because of straight cut gears. Another gentleman who’s been driving nearly as long as I’ve been alive told me that auxiliary boxes are typically only rated for up to 900 lb ft. of torque.
    I’m curious because I have found examples of drivers mentioned on YouTube who have always had a twin stick hooked up behind a relatively high output engine. Old School Jerry on The Flannel Phillip channel has one behind an N14 Cummins (1650 lb ft.). Another guy mentioned, called The Lettuce King, out of Canada has always had one hooked to a 3408 Caterpillar (1800 lb ft.)
    So I wanted to get your take and your experience. Is it true or is it just a myth? I know that you can have one put in a brand new 389 (as of a couple years ago) but Peterbilt will not cover it under warranty. Thanks for all the input.
    ~Josh
  3. Oxbow
    Oxbow Road Train Member
    12,927
    134,118
    Nov 24, 2015
    There are plenty of folks that run them behind higher horsepower engines.
    They won't last as long as new transmissions and need to be driven with care, like avoiding full throttle at lower rpms, but they can work.
  4. staceydude
    staceydude Road Train Member
    1,146
    4,993
    Apr 3, 2020
    There is an interview on big rigs videos from 3 Bar C and he runs 1000hp cats in his two trucks and that 79 KW has twin sticks.
  5. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    I’ll check it out!
    Oxbow Thanks this.
  6. REO6205
    REO6205 Road Train Member
    13,171
    60,501
    Feb 15, 2014
    California.
    We run quite a few twin sticks behind Cat 3406s. We've had good luck with them lasting but most of the drivers know how to handle them without tearing anything up.
    If you're getting sticks just because you want them you'll probably be okay. But if you have somebody else drive that truck you better make sure they know what they're doing.
    No shame in getting an 18 spd.
    JolliRoger, 25(2)+2, Sons Hero and 4 others Thank this.
  7. OLDSKOOLERnWV
    18,489
    278,948
    Like many other things with these trucks, what you do with your right foot has a big effect on the longevity of the transmission.
    There’s a few guys out here still running sticks, and with bigger HP, it’s just knowing when to use all them horses….
  8. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    Just go by the numbers. 1406A and 1241C, that one of the over-over 6+4 sets. 1400ft/lb main and 1200ft/lb auxiliary. And they sold them to us screwed to 3408’s and KT’s with 38k rears. With the a-box in the low hole I’ve wound 1810 shafts up tight enough to pull the slip yoke out and never hurt the boxes. The truck I have now has had an RTO14715 in it for 8yrs, on a C15 that puts up about 2100ft/lb. It’s all in how you drive them, truck drivers didn’t have many problems. Now you give people 2000ft/lb clutches and transmissions with 46k diffs and they still manage to smash the #### out of everything. It’s not the torque rating of the components causing that, they’re more about warranty liability than anything.
    JolliRoger, pete781693 and jldilley Thank this.
  9. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    There's a couple members here that are running Twin box's behind some serious Hp motors..
    As @Oxbow said you better know what your doing and when too & when not to shift otherwise your gonna have a pile of toasted scrap metal
    There's little tricks and improvements that need to be done with higher hp motors in front of them .. but thats a whole different subject of another day
    I ran a 5 & 4 behind a 3408 for years .. got along well with that combination
  10. TripleSix
    130,442
    And the number one reason why the big carriers are going to autos and detuned gutless engines.
    The stronger the engine, the most finesse is required from a driver.
  11. kranky1
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    Those guys never learn. Remember when they bought all those 290’s for the fuel mileage? That worked out well for them.
