Two questions on older trucks, what are the signs a rebuild is needed? and how do
Discussion in 'Ask An Owner Operator' started by CVMA, Jun 27, 2014.
  1. CVMA
    CVMA Bobtail Member
    30
    13
    Apr 23, 2014
    the rebuild/glider kit companies get 8 mpg out of a 2001 or older truck? If I buy a pre-EPA/pre-EGR truck, what is the least work I will need to do to make it reliable and 8 mpg for long distance, coast-to-coast running? (sorry I lied, that's 3 questions!)
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Rebuild everything! If you buy a glider you must pay taxes on a new truck. You can't get 8 MPG out of a 379 with a 500 CAT, so that's not the answer. Avg on mine @ 32 K was 6.8 to 7.2 Sea -BALT
  4. snowwy
    snowwy Road Train Member
    20,553
    13,281
    Jul 6, 2009
    when i did my training. in 1999. the 2000 FL my trainer was driving. averaged 6.3 with a reefer. going from the rocky mountains to south carolina and back.
  5. JAYRODPA
    JAYRODPA Light Load Member
    157
    109
    Dingmans Ferry pa
    Don't buy anything aver a 03. after that there all junk. because of the EPA. Look for smoke from the stacks.(white or black). oil in the radiator or water in the oil. But most trucks will be clean up and fluids change. watch for soot from the stacks at start up. Buy a scan guage D. you can plug it into the truck and get fault codes, MPG, Mileage ect. Get the vin and do a truck search to see if it was in a accident and who and how many owners. If there isn't any receipts to show repairs, it kind of hoping you made the rite chose and see what happens. Try Damiron.com I bout a truck thew them. good trucks, Good people and a fair deal. Good Luck
  6. cbholister
    cbholister Light Load Member
    164
    346
    Aug 30, 2010
    Overthere
    What's a good price for a scan gauge?
  7. CVMA
    CVMA Bobtail Member
    30
    13
    Apr 23, 2014
    thanks a lot! I will look at Damiron.com. Didn't they start adding the EGR valves in 2003? I thought I had to get a 2002 or older...
  8. JAYRODPA
    157
    109
    Dingmans Ferry pa
    No. egr started in 04. but look. there may be some late model 03 listed as 04. make sure it a scan gauge Diesel. new, around $150 give or take. you can get them cheaper on ebay used
  9. cbholister
    164
    346
    Aug 30, 2010
    Overthere
    I can get one at advance for 110 plus tax. I just wanted to make sure it was a good buy.
  10. JAYRODPA
    157
    109
    Dingmans Ferry pa
    $110. buy it. good price. If you dont mind waiting. check ebay and Amazon. you mite find it cheeper. just look at shipping cost.
  11. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    That is probably the scangauge E. You need the Scangauge D ($160) or Scangauge KR ($200)
