Type of Wood for Bottle Jacks?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Jan 4, 2020.
  1. PE_T
    PE_T Road Train Member
    What type of wood should I be using to place under a 12 ton bottle jack? I’m thinking those who haul flatbed may know as they occasionally use pieces of wood to protect the trailer floor?
    Reason for edit: Spelling
  3. AModelCat
    158,710
    Proper shop practice is hardwood blocks that are free of cracks. I have used softwood blocks when it comes to big stuff (like 24"×24") just due to weight. One of those 3 feet long is heavy enough in softwood. You'd need a forklift to move a hardwood block that size lol.
    Hulld, spsauerland and PE_T Thank this.
  4. Tb0n3
    Tb0n3 Road Train Member
    4,558
    9,070
    Oct 5, 2012
    Earth
    Flatbed typically uses hardwood 4x4s for real heavy stuff, but it's unweildy and sometimes pine works just as well. Not quite what you'd want I imagine.
    PE_T Thanks this.
  5. xsetra
    xsetra Road Train Member
    5,111
    6,975
    Aug 21, 2011
    What are you putting the wood on. How high is the wood going to be.
    I've used hardwood and softwood as a base. Also used steel and aluminum.
    Important is make jack plumb and level.
    PE_T Thanks this.
  6. PE_T
    I’ll be putting a 12 ton bottle jack on top of it. I think I’ll need at least 4” wide. So a 4x4 perhaps. Do you think Home Depot carries this type of wood?
  7. Ridgeline
    22,384
    116,205
    Don't bother with a 4x4, if that jack has a 4inch sq base you need something bigger, I would think that a 10x10x8 oak timber would be your best bet. It isn't as heavy as it sounds and seems to hold up the best. I have a few from the 1930's that I still use to lift cars off the ground to save the tires. By the way, you can find them all over the place, any large city will have a place and it should be about $30.
    Goodysnap and PE_T Thank this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    Ditto on the Oak or hardwood.
    6x4 or 8x4 are good manageable sizes. Plus you can angle cut and use them as small ramps. Jack up and place under tires and drive off when completed.
    HopeOverMope, Rideandrepair and PE_T Thank this.
  9. PE_T
    Interesting idea.
  10. skellr
    skellr Road Train Member
    8,737
    12,185
    Jul 17, 2011
    The Village, Portmeirion
    Oak. What are you lifting with the bottle jack and what kind of ground are you lifting it from? dirt, sand, gravel?
    I would use at least a pair of 2x4 oak directly under the jack and then fir or maybe pine under that to spread out the weight. Only hardwood directly under the jack as it will cut through softwood too easy.
    PE_T Thanks this.
  11. PE_T
    I plan on eventually lifting my truck frame from the front to remove the oil pan. It looks like it needs a new gasket.
