I have no problem with the U/A and will have no problem passing it. But do i really HAVE to fill the cup while someone watches? Have enough problems trying to void during a ballgame with 10 dudes doing the same on each side and a line behind impatiently waiting! If I ask to void in private am I gonna automatically make my co. suspicious?
U/A Viewer Necessary?
Discussion in 'Questions From New Drivers' started by stealfire, Jan 1, 2011.
You most likely will be in a bathroom by yourself with all the water turned off or in a stall with the examier in the room. Only if you flunk one or they suspect you cheating will you be required to be watched
If they suspect you cheated in a UA they get this X D.M./ company nurse to watch you on your re test!
They have pee cams in the bathrooms that have a live feed to this forum... do a search for 'little winky'....
I use to 'do' U/A's when I worked at a Doc in the Box... it depends on the company's requirements... some you HAVE to be in the same room (single stall) as the person (same sex only) - others you have to stand outside the door (to listen for water) and others you have to make sure you put blue coloring in the water of the toilet. Figure the person (if they have to be in there with you) will have seen SO MANY others - you won't stand out in their mind at all. They probably don't want to be in there either - LOL!
Last time I went in for a return to work medical (not a regular physical) my boss was required to come into the room with me and be present. We both thought it was a little extreme but it was a company requirement
No!!! They send you into a bathroom with your pockets emptied and ask you not to flush the toilet until they inspect(although I have never seen anyone do that) No one watching has been my experience...although there were a couple of cute nurses I wouldn't have minded if they peeked!!!!
lol They can watch me pee all they want. Unless my girlfriend is the one doing the viewing, they better be prepared to wait a while!
