U-bolt torque for Freightliner Airliner 2 suspension
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MRMTRANS, Nov 19, 2022.
  1. MRMTRANS
    MRMTRANS Medium Load Member
    342
    381
    Apr 28, 2015
    I want to know if anyone knows the MAXIMUM torque for these u-bolts. They are 7/8" x 14 tpi (maybe 16). i just put in new spring bushing and want to torque as high as possible without thread stretch so the spring doesn't towards the center of the truck, misaligning the airbag and axle. This a common problem with old Centuries and FLDs. My manuals say 450-550 ft-lb. But I've heard you want to torque more on on this suspension. Thanks in advance
  3. AModelCat
    154,966
    I think I always ran them up to 550. I always supported the frame too so I wasn't fighting the weight of the truck as well.
  4. AModelCat
    154,966
    I always cleaned off all the surfaces down to bare metal. Paint and rust are a huge part of parts moving around. They almost act like a lubricant.
    xsetra Thanks this.
  5. MRMTRANS
    342
    381
    Apr 28, 2015
    All the above done. I pulled spring out to push out old and push in new bushing on a shop press. Cleaned off rust with heat and wire wheel on an angle grinder. Frame still supported-had to raise to remove air bag. Do you know what grade metal the bolts are? I assume 10 grade.
  6. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    Just my experience on my 07 Columbia.
    I welded some metal tabs on the inside of both bottom bridges and then socked the U bolts down tight with my inch drive air impact and they have stayed aligned and tight now for about 4 years or so.
  7. MRMTRANS
    342
    381
    Apr 28, 2015
    Well, I removed 1 sping 2 years ago because it kept shifting. I cleaned off all rust, filled gaps left behind from corrosion with JB Weld, and smoothed out. I retorted the u-bolts twice after and it hasn't moved that I can see. I am replacing 3 other bushings, and cleaning up springs at the same time, but no JB Weld this time so far because the corrosion isn't near as bad. But I do maybe want to push beyond the torque limit when no JB Weld. Just wondering if anyone has torqued to say 700-800 ft-lb and cured the spring shift. Obviously I worry about thread stretch and being counter productive.
