Ultrashift vs Manual
Discussion in 'Ask An Owner Operator' started by BCDONALD, Mar 5, 2013.
  1. BCDONALD
    BCDONALD Bobtail Member
    29
    4
    Feb 17, 2013
    I am looking to buy a new/used tractor and am wondering if an ultrashift will give me the best mpgs. Also are they reliable? What is considered a reliable tractor setup/make getting mpgs in the 7-8 range? I hear Volvo can acomplish this along with a smooth ride, but a mechanic told me the newer ones have a lot of problems and repairs.
  3. WRIGHTRACING
    WRIGHTRACING Heavy Load Member
    882
    251
    Jan 3, 2011
    Iuka MS/Muscle Shoals AL
    Manual is best for fuel mileage....you control the shifts. Autos downshift when not needed, and hold gears way longer than needed. They want shift out of first and second below 1500+ rpms.
    As far as trucks, Cascadias are best for aerodynamics, then the setup is what makes the entire difference for final MPG.
  4. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    I suggest you look to MVT for specs. They run the Pro Star and avg 9.3 across the fleet on the Interstate.
    JMO
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    I have test driven a few autoshifts, they all seem to need to wind up more to shift than what I can do with a manual. And with an autoshift you have the possibility of sensor, solenoid, ECM and wiring problems that are not on a manual, and can be expensive to fix.
  6. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,995
    9,712
    Oct 18, 2010
    NW Indiana
    I have never driven an autoshift. That being said lets look at why they even exist. Most of the companies that spec autoshifts do so for 2 reasons: To attract totally inexperienced drivers and or female drivers. I have spoken to several drivers in our 300 truck fleet of owner operators who have purchased them both new and on used trucks. Our drivers average 25 years experience in the industry. Everyone of them say never again. Too complicated and too expensive to repair. An experienced driver who is paying attention to his work can do as well as the preset computer in the autoshift, and in many cases better.
    I wouldn't think of purchasing a used autoshift because of the likely abuse it has encountered at the hands of inexperienced drivers, and the fact that that fleet intended to get rid of the truck within or close to the end of the warranty period, so their maintenance program is absolutely minimum. If you know have to handle a non-synchro trans, which is likely the case, here is one case where modern technology is not cost effective.
  7. BCDONALD
    29
    4
    Feb 17, 2013
    What do you mean look to mtv for specs?
  8. WRIGHTRACING
    882
    251
    Jan 3, 2011
    MVT=Mesilla Valley Trucking out of Las Cruces NM. They have every fuel economy gadget you can think of and drive ProStars.
    chalupa Thanks this.
  9. chalupa
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    They are also the undisputed leader in interstate fuel mileage. Last advertised a 9.3 mpg fleet average.
    Do what they do and enjoy.........
  10. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    All of the auto shift / ultrashift transmissions can be put into manual mode and the driver can select the shift point. I do not have one, but I have tried several in various trucks over the years and there is not one I could not put in manual mode and flip a lever or push a button and have it shift when I wanted. I even would skip shift them. I will agree, left to their own, many of these transmissions do not shift at optimum intervals all the time. That is why I usually did manual mode when I drove them. They will get just as good or better mpg than a straight manual transmission. Like most things, it is all in how the driver drives the truck.
    As for companies buying them to attract new drivers and such, I am not so sure. I think it is more a matter of operational cost. While these trannies do have their problems, a fleet still has to deal with both new and "experienced" drivers beating the snot out of their equipment. Using autoshifts helps to eliminate the down time of blown clutches, damaged clutch brakes, and damaged transmissions. Face it, it isn't always about experience so much as it is about attitude on how someone takes care of another man's equipment. Just watch how a lot of drivers shift in truck stops and dock areas. Makes a person want to cry on how abused a truck is.
    kerosene jockey Thanks this.
  11. WRIGHTRACING
    882
    251
    Jan 3, 2011
    The first 2-3 gears will not shift when you want them to. I drive one daily and it won't do it. Manual mode is good once you.get into 4th and above.
