Uneven psi in tires?
Discussion in 'Questions From New Drivers' started by dboot01, Mar 19, 2022.
  1. dboot01
    dboot01 Light Load Member
    125
    213
    Nov 8, 2021
    I have super singles. 3 of my drives are right around 105 psi and 1 of them is 98 psi. Is this a big deal? Does that 1 tire hurt my fuel economy? Thanks
  3. Mr Uturn
    Mr Uturn Light Load Member
    178
    216
    Jul 30, 2021
    Why is this even a question. If you took the time to gauge all the tires. Spend another 3 minutes and air up the low tire.
  4. dboot01
    125
    213
    Nov 8, 2021
    Where do you go to air them up? Lolll
    tscottme Thanks this.
  5. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    855
    1,666
    Dec 15, 2021
    I think the Michelins can go to 130 for best fuel mileage but you will loose a lot of traction .If it's icy or snowing we drop ours to 90 or 95 if the load is light and winter driving conditions.
  6. Mr Uturn
    178
    216
    Jul 30, 2021
    Not sure if your joking or not? So will answer.
    1) At Lovers the first fuel pump has something called tire pass. Where they check and fill your tire pressure.
    2) Most T/A and Petro have a ait hose either on the pump or at the shop.
    3) Pilot and Flying j with a shop have air hose. Either at the pump or at the shop.
    4) Most buy not all mom and pops have same answe as 2 and 3.
    5) At truck stop, walmart, amazon, where ever you shop. Purchase an air line that hooks up to your trailer (red line) air supply. Then you can fill a tire anywhere you have access to a tractor. Best part is once you purchase one. You always have it.
  7. Lyle H
    Lyle H Road Train Member
    1,291
    2,937
    Apr 16, 2014
    You have to call road service. This is a dangerous situation that must be taken care of immediately. They surely taught you this in that expensive school you went to.
    Sigh……
    supergreatguy Thanks this.
  8. GreenPete359
    GreenPete359 Road Train Member
    2,152
    5,101
    Oct 21, 2017
    Driving my recliner
    Why are you guys razzing this guy? All these trucks have auto tire inflation. All he has to do have the shop recalibrate his switch in the truck.
    Op you should yell at your shop too. They should have taught you how to work the the tires switch in orientation.
  9. ncmickey
    ncmickey Road Train Member
    3,830
    7,145
    Jun 21, 2013
    Durham NC
    201 Road Train Member
    12,330
    25,213
    Apr 16, 2014
    high plains colorado
    Ha, ha, big joke, where to get air? :biggrin_25513: We're doomed,,,DOOMED, I TELLS YA'.
    T.Rucker Thanks this.
  11. Moosetek13
    Moosetek13 Road Train Member
    14,676
    18,450
    Nov 1, 2010
    Burnsville, MN
    They no longer use that first fuel lane. Now you have to go to the shop for the Tire Pass service.
