Uniden PC78XL problem
Discussion in 'CB Radio Forum' started by tomsexpress, Feb 26, 2010.
  1. tomsexpress
    tomsexpress Bobtail Member
    Albuquerque, N.M.
    I've had this radio for about four years now with no problems. The other day it quit transmitting and receiving. Stopped at a CB shop in Idaho and the tech said the finals were blown. He fixed it up and it worked for about twelve hours and quit again. It's a stock radio with an Astatic mic, no kicker. Twin Wilson 2000 antennas. What could be causing this? Thanks
  3. Firebird
    Firebird Light Load Member
    292
    56
    Aug 13, 2006
    Bristol, VA
    I had the same problem with a PC78Elite. Turned out to be a bad antenna coax causing a bad ground. Is your ANT light coming on when transmitting? Have you checked your SWR? Is it good?
    I bought a K40 Antenna and a new coax and it solved the problem after having the final replaced.
    Good luck,
    Dave.
    squirrellsgnwild Thanks this.
  4. tomsexpress
    Albuquerque, N.M.
    Thanks for the reply Dave. The antenna light doesn't come on when transmitting. The coax makes sense as it's been shaking around in there for 11 years now. I haven't checked the SWR. I've got a down day tomorrow so I can tear into it.
    Tom
