United Pacific headlights on '00 Pete.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bovinemoovers, Jan 14, 2013.
  1. Bovinemoovers
    Bovinemoovers Bobtail Member
    26
    Oct 30, 2012
    I just swapped out the headlights on both sides. It had the single headlights when I bought it, but one had a cracked base and so I just bought another set of headlights, same brand and installed them. I matched wires up just the way they came off, but when I turned them on they seemed to dim normally in the daylight but the headlight indicator on the dash stays on all the time and they are very dim on dim and maybe normal dim on bright?? I unhooked the left headlight and the dash light works right but the right light is backwards, bright on dim and dim on bright. When I unhook the right side with the left side hooked up the dash light stays on all the time. What is my problem???
    William
  3. RedPete95
    RedPete95 Light Load Member
    176
    39
    Feb 5, 2009
    Erie, PA
    Sounds like a ground and crossed wires. You should only have 4 wires running to the singles. That's how mine are setup anyways. Test all wires and mark them if you have to. I can't remember which colors are which though. Hope this helps
    Bovinemoovers Thanks this.
  4. Bovinemoovers
    26
    Oct 30, 2012
    I'll try that as soon as I find a light. Wouldn't you know the batteries in the test meter must have went bad!
  5. Bovinemoovers
    26
    Oct 30, 2012
    Could it be a bad bulb or something? I swapped the wires on the right side thinking since it was backwards that would fix it and no deal still backwards?
  6. pawpaw1
    pawpaw1 Medium Load Member
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    i have UP headlights on my KW now. The wiring Colors are different , from united , and the Factory. Factory colors are ###-backwards , IMO. I think , on the factory , white is ground , black is low beam ,and green is high beam.
    Don't hold me to that , though. I just remember I had to write it down , to get it right.
  7. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    When my factory square single headlights(3 wires each high low and ground) did the exact same thing, it was a bad headlight relay in the fuse panel.
  8. Bovinemoovers
    26
    Oct 30, 2012
    I did find a bad relay, now I just have to get time to find one. Truck stop only had a small one. Hopefully this will fix it.
