Unknown engine error code
Discussion in 'International Forum' started by gabton-tankers, Aug 20, 2014.
  1. gabton-tankers
    gabton-tankers Light Load Member
    92
    6
    Feb 11, 2014
    Can anyone help me with this engine error code?
    Code:
    J128P385BA J136S002BA J13 Engine #1 (MID 128) reports Unknown PID (PID 385) is Data valid but below normal operational range.
    I searched google and this forum and came up short.
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    I just caught this on the side bar, don't normally check the International section, but you may want to post year and what engine. If it's an Acert Cat engine, PID 385 is for the intake actuation oil pressure.
  4. gabton-tankers
    92
    6
    Feb 11, 2014
    Forgot! 2007 international 9200i with acer cat engine c13.
  5. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    The intake actuator pressure sensor is in the right side top of the engine near the front. This sensor often fails, but it could be a wiring issue or a problem causing low oil pressure in the intake actuator system. The sensor is about $130. It may not be the sensor, but I'd try that 1st, even it it's not, throw it in the truck, you'll change it eventually, they fail. Check the wiring and the connector at the sensor. If it's not the sensor or wiring, it could be an internal leak under the valve covers causing an oil pressure loss to the actuator system. The housing can crack, or the oring can blow out of the the bridges that feed oil from the head to the housings. Is engine oil pressure ok on the guage?
