Unplugging egt sensor fixes low power issue. But why?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Car Runner, Apr 13, 2022.
  1. Car Runner
    Car Runner Bobtail Member
    21
    18
    Jul 29, 2013
    Utah
    Thanks to all who make these forums great.
    2013 VNL 430 D13- 600K
    Truck boost builds to usually 10-12 psi (but can vary 8-20 psi) then stops and engine shutters. So the problem is more pronounced when loaded and on hills where boost is required. This always happens between 1400-1600 rpms. fuel pressure always 60psi plus, Turbo speed maxes at 90,000 rpms. Seems to also be temperature related. The first minute it runs fine.
    If I unplug the egt sensor on the cross over tube, the problem is gone. The truck runs great unplugged.
    Codes are SPN 1127 FMI 10,14,18. All turbo related.
    New-Batteries, Batt cut-off switch, Engine wiring harness, Delta P sensor, MAP sensor (4 times), egt temp sensor, CAC boots, Turbo, fuel filters, oil filter, coolant tank, new dpf gaskets on install, overhead completed,
    Cleaned-DPF, DOC, egr, egr cooler,
    Tested-turbo before replacement 4 times, EGR was replaced with a new one and problem still there, relative cylinder compression, fuel pressure, clear tube test, ECM swapped at Volvo and tested (old ECM re-installed), DPF after cleaning, boost test to 25psi (tiny leak in CAC), blow by passed
    Programmed- turbo actuator twice from Volvo and another shop.
    Like I said it runs great if egt sensor is unplugged. My next guess is the egr oil lines. Particularly the return line. Does anyone have experience that can point me in the right direction?
  3. loudtom
    loudtom Road Train Member
    1,717
    2,803
    Aug 26, 2016
    My truck would derate when the exhaust gas temperature got near 900F. There are no codes or engine lights, it just wouldn't build boost until the temperature stabilized. If your truck is running hot, and you unplug that sensor, it has no way of telling the ECU that the temperature is too high.
    I would rule out sensor problems by verifying that the truck is overheating. Oil temps above 220F, coolant near 210F, and exhaust temperatures that climb rapidly while building boost indicate to me that my system is overheating. My D16 always runs a little hot, but those are the temperatures I expect from climbing a steep grade, not normal highway driving. Coolant usually sits around 190, oil about 210, and EGTs range from 550-700.
    It looks like you've already replaced a lot of components that I would have looked at. In my case, a faulty EGR valve was allowing exhaust gases to bypass it, possibly combined with a bad injector. If your truck is running hot, I would resist the urge to run with the sensor unplugged.
  4. Car Runner
    21
    18
    Jul 29, 2013
    Utah
    Thanks for your reply. Your response got me thinking. If the truck is not heating up then maybe it is the egt sensor. After the truck spent an additional 20 hours at Volvo getting diagnosed, I did not consider that the egt sensor after the exhaust side of the turbo may be the culprit. This truck does not have a dash egt gauge. It may be in the digital options.
    I will confirm my oil temp and egts tomorrow.
    Coolant 175 degrees running flat ground at 70mph load with 72K, 1600 rpm. On hills coolant goes up to 195. Fan kicks on and holds it there. 80 degree outside temp.
    The truck will exhibit the problem bobtailing around the block.
    For the threads information the old crossover temp sensor’s ohms were 220. The new Volvo sensor was 230. No change in truck performance so I think this is a good value if trouble shooting.
  5. Car Runner
    21
    18
    Jul 29, 2013
    Utah
    Temp ambient—85
    Gross weight—73K
    Oil temp warm idle—205
    Oil temp flat is—
    Oil temp hill—240-245
    Coolant warm idle—168
    Coolant flat—175
    Coolant on hill—195
    Oil pressure warm idle—17-37psi why does this change?
    Oil pressure flat—60psi
    Oil pressure on hills—60psi
    EGTs idle—290
    EGTs hill—750
    After searching oil temps on the D13 on the forum it looks like 240 is normal. Post title is “2014 D13 Oil Temp”
    My oil temp looks normal.
    I also checked the egr valve outlet orifice and there is a screen that would prevent any chunks from the inlet line or parts of the egr valve breaking down and flowing back to the engine.
  6. Car Runner
    21
    18
    Jul 29, 2013
    Utah
    Any additional information or interpretation of these numbers or this problem would be appreciated. Thanks
  7. Car Runner
    21
    18
    Jul 29, 2013
    Utah
    Wait. I have one more thing to check from your suggestion. I’ll post back tomorrow.
  8. Car Runner
    21
    18
    Jul 29, 2013
    Utah
    Didn’t change. Plugged in or unplugged the numbers are the same. So, I still need help on this one.
  9. Car Runner
    21
    18
    Jul 29, 2013
    Utah
    I have cleaned the air side of the egr cooler. Is there a screen on the coolant side of the egr cooler that can get blocked? Does the coolant part of cooler get plugged? I will take a temp reading when, the truck is hot, of the inlet and outlet air tubes of the cooler. I’ll use a IR temp gun. Does anyone have the inlet and outlet temps of the coolant and air for this heat exchanger? Or the delta T?
  10. Siinman
    Siinman Road Train Member
    5,435
    13,973
    Mar 5, 2017
    Kansas City, MO.
    You may want to check in on the Facebook group Volvo Truck Masters. They tend to have a little more help when it comes to stuff like this on Volvo.
  11. Siinman
    5,435
    13,973
    Mar 5, 2017
    Kansas City, MO.
    Also there is a Volvo forum here as well that has some better help. Maybe ask mods to move it to that area and will get more help.
