Unsecured load ticket...need advice.
Discussion in 'Experienced Truckers' Advice' started by screamin eagle, Nov 3, 2011.
  1. screamin eagle
    screamin eagle Light Load Member
    103
    39
    Apr 18, 2009
    texas
    I received a ticket for an unsecured load and need experienced flatbedders advice.
    The load was a pyramid load of 5 3/8 " drill pipe 40 ft lenght. Nineteen pices on the bed, four high,, i had nine straps on the load plus a gut wrap in the middle. Because the two inside pieces of the third row did not have a strap touching them i was giving the ticket..
    I have never had a ticket before and am wondering if i should fight this,, I know the DOT regs, but they are unclear on pipe, at least what i have read..
    Any advice is appreciated.
  3. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    That CAN be a rather serious ticket,
    I'd suggest talking with an attorney.....
    Wargames Thanks this.
  4. volvodriver01
    volvodriver01 Road Train Member
    I have hauled alot of pipe out of Indiana up to milwaukee. All I ever do is throw my straps over the top of the pipes. How ever many you may need to meet the wieght of the load and then I also use a gut strap every once in a while. I have had many inspections and always pass. I usally have a couple pipes with no straps touching them. I would get a lawyer and fight it.
  5. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,058
    Jul 15, 2007
    TEXAS
    If your still under the load. Take pictures of all sides of the load if you plan on fighting it.
    Wargames and 123456 Thank this.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I'd fight it too. I'd say he is thinking of chocking and securing it from rolling. As long as you had the pipe cradled, he has no way of proving that the load would shift. What is it, 0.25 or 0.5 g's or something like that. He has no way of proving it. He's just speculating. A lawyer can get you out of that.
  7. Meltom
    Meltom Road Train Member
    5,423
    3,019
    Jan 24, 2011
  8. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    Fight it. Certin states are starting that bs with us hauling logs and i can tell you from doing this over 22 years its almost impossible to get a strap to touch every single log going across the top.
  9. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,733
    Jan 30, 2010
    keep stroking.
    fight it you had more than enough straps on it as long as they were about 10ft apart and rated for the weight. all securment is half of load weight. 10,000 lb straps on a 40,000 lb load,4 straps is all that is required. for what your talking about as long as they are tight against other pipe they are secure. a strap doesn't have to be touching them.
  10. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Had a driver get one for having 3 coils with 2 chains each suicide. He normally hauls them shotgun with 2 chains and a strap over the top. Since they were suicide he didn't have the strap and wrote him up for 3 violations. (according to the weight of each he needed 2.3 chains per coil) When the actual fine showed up it was only $100 and showed only one violation. Unless your record is bad I personally wouldn't waste my time for $100.
    Sounds like your cop was being an dick. Problem is if you were legal and he gets away with writing the tickets then he's going to be busy writing more.
  11. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Don't show those in court unless your attorney says to.
    Make them prove the violation.
