Upgrading from a B to an A
Discussion in 'Questions From New Drivers' started by Bdog, Apr 3, 2016.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    My buddy has a class B license with no air brake restriction. He wants a class A. Can he take the road test in a class A combo without air brakes like a dually pickup with a ten ton trailer or does it need to be an air brake class A vehicle?
  3. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    He may be able to, would have to call the state. He may get a auto restriction though, best to call.
  4. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Side note, been sooooo long since mine, alot has changed
  5. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    If he takes it in a combination vehicle without air brakes, he will have an air brake restriction on his class a license. He also has to test in a vehicle representative of the type he will be driving. Hence he will be restricted from driving tractor trailers. He will only be allowed to drive truck trailers w/o air brakes.
  6. Bdog
    1,057
    877
    Nov 6, 2014
    Ok. Wasn't sure. He has the air brakes on his B from driving dump trucks. He just wanted to upgrade to an A. I could let him test in my Pete and 53' but he has never driven anything like that. Thought it might be easier for him if he could just test in the pickup with the big gooseneck which requires a class A.
  7. Mikesee
    Mikesee Light Load Member
    90
    51
    Oct 25, 2014
    Talk to your local DMV and ask them what he needs to do.
  8. Ridgeline
    22,404
    116,518
    Take the air brake test, it is really easy, easier than the combination test which is also easy. Once that's out the way, just take a road test and be done with it.
  9. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    I've heard of taking the test in a dump with airbrakes and an equipment trailer for the >26,000lb limit for a full class A, but I've not heard of it in a 1ton dually.
    Good luck!
  10. Dominick253
    Dominick253 Heavy Load Member
    746
    634
    Nov 19, 2015
    Yes. They won't want to but if you can get a ticket for driving it because you don't have an A then you can use that vehicle to get your A.
  11. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    You used to be able to do that in mn, don't know anymore, no air brakes endorsement but if you already had it, it was accepted
