Upgrading lease truck
Discussion in 'Swift' started by Rick)Rox, Apr 17, 2014.
  1. Rick)Rox
    Rick)Rox Light Load Member
    114
    43
    Jan 30, 2013
    Tacoma, WA
    Hey all I got a question for all you lease operators out there. I just leased 2015 cascadia evo and got it upgraded to a 13 speed which was easy. Recently I bought a scan gauge that hooks up to the ecm and has readouts like for boost, instant, and avg mpg which is handy for adjusting the way I drive. I know its not completely accurate for calculating mpg but it is handy for getting a rough estimate. Anyways it also has a gauge that reads what the current horsepower rating the engine is putting out... now I don't know what my engine parameters are but the max readout was 300hp. I don't know if its accurate or not but according to the top of the engine its rated up to 505hp. Can I take it to a dealership and get the ecm tuned for a higher hp? I figure the higher the hp the more efficiently my truck will run. But there is such a thing as too much hp where i'll be losing mpgs. Thanks for the help!
  3. jabekins
    jabekins Bobtail Member
    37
    17
    Apr 16, 2014
    Warrenville,IL
    Wide open is always the best your fuel is base on how heavy your foot is on the pedal.
  4. roshea
    roshea Road Train Member
    Most dealers probably won't touch this since the truck is leased and not in your name. Also may require a password to get into the ECM. Back of the parking lot truck stop "tuners" may or may not do this for you, they wouldn't want Swift coming back to them if they found out about it.
    The scangauge doesn't show the true HP anyway, I know mine isn't even close, so don't worry about that.
  5. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    Yeah, he's right, you don't own the truck, your name is not on the title so you will have to ask the 'Owner' if it is OK to do the modifications you want. Did you get this lease through Swift? If so, it's their call and I think I know what the answer will be.
  6. spyder7723
    spyder7723 Road Train Member
    15,471
    25,074
    Mar 31, 2013
    sarasota, fl
    You poor #######. Good luck on that lease, you're gonna need it.
    You can calibrate the scan gauge but fiddling with it while the truck is on a dyno.
  7. Rick)Rox
    114
    43
    Jan 30, 2013
    Tacoma, WA
    Thanks for the info guys. Its not such a big issue more curious about it than anything.
    Um I'm guessing you called me a stupid donkey thanks, I really need to be ridiculed for me decision. But, thanks for the helpful info on the scan gauge.
  8. Dryver
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    Is that the truck in the photo? Why would a Swift truck need the extra lift axle? Just curious.
    Good luck with the lease.
  9. roshea
    Another possible option, not cheap though, is to get the BullyDog HDGT device then you can change things on your own. Also revert back to stock for when the truck has to go to the shop or dealer. However I think if the ECM has a password set you can't use it. From drivers I've talked to that have one they say they do have fuel savings and a bit more power and it will pay for itself. No personal experience to say either way.
  10. Rick)Rox
    114
    43
    Jan 30, 2013
    Tacoma, WA
    No it's my old company truck, running 105k gross
  11. Trafficcontrolxl
    Trafficcontrolxl Medium Load Member
    487
    445
    Feb 19, 2009
    Omaha, NE
    Every scan gauge I have played with maxes out around 300 hp. You can go into the settings and calibrate it.
