upgrading mic.
Discussion in 'CB Radio Forum' started by Holiday112511, Feb 7, 2014.
  1. Holiday112511
    Holiday112511 Bobtail Member
    15
    Jan 28, 2014
    Im looking to upgrade to a better mike. I have a cobra 29LTD. What is a good mike?
    RKONRADE Thanks this.
  3. juanveldez
    juanveldez Light Load Member
    152
    44
    Apr 24, 2007
    Iron Mountian MI
    I have run an Astatic 636 and a Ranger SRA198 both are good. You could also look at the Road king 56.
  4. Holiday112511
    15
    Jan 28, 2014
  5. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    One thing you might consider is watching a few videos on YouTube featuring mic tests. You should be able to search and find several videos on the subject. With that being said, I will second juanvaldez's opinion. Personally, I like the RK56 best, but it is definitely a personal preference thing. Many people use one of those 3 mics and have great sounding audio.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Astatic 636L. SRA -198's are both excellent Noise Cancelling Mic's...RK 56's "Use to be" back when Turner was still making them...Since Barjan took over production, they are hit and miss...(mostly "miss") not to mention "over-priced".
    Another option is the RF Limited Xtreme 2018...The 2018 is a good match up for the 29's since not only is it a Noise cancelling Mic, but also a power mic, and a echo mic, and priced about the same as the RK 56's.
    ShooterK2 Thanks this.
  7. Offender
    Offender Light Load Member
    99
    138
    Oct 25, 2013
    2003 Columbia HWY
    Astatic 636L or a SkyThumper 65DX
    I use astatic for the ptt buttons size and location.
    The skythumper is a better mic tho, but just barely. IMO
  8. cuzzin it
    cuzzin it Road Train Member
    3,639
    11,687
    Jan 19, 2008
    Berea, KY
    i have a Astatic mic on my 29 LTD.... quite happy with it
  9. The Bulkmatic Grasshopper
    The Bulkmatic Grasshopper Bobtail Member
    40
    17
    Apr 4, 2012
    Kentucky
    Astatic 636L's (with the stainless steel chords) are what I use, exclusively, on my cb radios (Cobra 29's & 25's).
  10. burnsey
    burnsey Light Load Member
    81
    40
    Jan 24, 2014
    seacoast, NH
    I put an Astatic Road Devil (RD104E) power mic on my Galaxy, it made a noticeable improvement in the audio volume when heard through the talkback. Had to turn the talkback way down to prevent the feedback. That mic preamp will help get your voice audio much higher than the background noise level.
  11. ShooterK2
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    I recently took JJD's advice and ordered a RF Limited 2018 Xtreme, and now that I've had a couple weeks to use it, I can also recommend this mic as well. I run a Uniden 980, and after two attempts to install an echo board (with less than satisfying results), I figured I'd try this mic. It's loud and very clear in all my recordings from the receiving radio, and it provides the slight amount of echo that I like in my audio. I do need to point out, however, that if you, like me, are used to using an RK 56, the shape of this mic will take some getting used to.
    jessejamesdallas Thanks this.
