Upgrading private equipment so need CDL
Discussion in 'Questions From New Drivers' started by mas, Dec 2, 2010.
  1. mas
    mas Bobtail Member
    5
    Hi All,
    With the apparent uptick in pulling over private trucks and trailers I have decided to get my CDL since I am also buying a larger trailer and truck (for private use in auto racing) and don't want to get hassled or even worse, parked going to an event!
    The truck is a Freightliner M2, auto tranny.
    The trailer is a 44' Wells Cargo gooseneck.
    Neither have air brakes.
    I went ahead and got my physical, passed my written general knowledge test and the combination test. Didn't take the air brakes test because I am not using a vehicle that will use them. I am trying to get my Class A.
    I am a little confused on where I go from here. I know I need to go do the pre-trip inspection and on road test but would I do it in my own equipment or will I have to drive something from the school? Also I don't have time to go through a trucking school for 3 weeks, I have a business to run to keep food on the table. I currently have a F250 and a 24' tag along that I pull now, since I do not have the new trailer yet (it's on order) could I go take the test in the equipment I own now or am I too heavy with the new truck and trailer to even bother?
    Any help or suggestions would be very appreciated!
    Thanks!
  3. Jbrake1960
    Jbrake1960 Light Load Member
    162
    132
    Nov 15, 2010
    Las Vegas
    are you sure u need class a? a vehicle over 26001 pounds?
    rocknroll nik Thanks this.
  4. o.m.d.
    o.m.d. Heavy Load Member
    827
    2,130
    Aug 15, 2010
    massachusetts
    pretty sure you need the air brake endorsement to get the cdl license. i think you're better off finding a non cdl option.
  5. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    OMD, its possible to get a class A w\o air brakes.
  6. mas
    mas Bobtail Member
    5
    The GVWR of the trailer is 22,500 and the truck itself has a GVWR of 8,845, so that puts me over the 26,001. The trailer is a triaxle, if it was tandem it would be 14,500 and I would be in the clear.
  7. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I would go ahead and say you could use your own set-up.
  8. o.m.d.
    827
    2,130
    Aug 15, 2010
    massachusetts
    hmm, i didnt know that. seems kind of pointless since every truck has air brakes or almost everyone at least.
  9. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    its private use so you do not need a cdl necessarily. and it is possible to get one with an air brake restriction. even if you pass your written test with air brakes, but test in a vehicle without them, you will be restricted. And I know its been discussed before, but you may have a manual transmission restriction on you cdl if you test in your automatic.
  10. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    A private motor carrier does not define if a vehicle is a CMV or not. Under the FMCSR's § 390.5 definations a private motor carrier is a unit that is not for hire. For example a Chevron truck is not going to be hired out to haul someone's product. They are exclusive to themselves. What defines a CMV is if that vehicle (since he's gone over the weight requirements) is involved in any commerce. If he takes his race car to the track and wins $100 then the unit that hauled it there is a commerical motor vehicle and is under all the FMCSR's. Which means he needs a CDL.
    What I feel is needed is a better definition of commerce. We've had this discussion before and there's been a couple of LEO's that say commerce could be a trophy or a discount on parts for showing that parts manufacturer decal on the car.
    If it were me I'd check it all over very carefully and maybe have a letter from the DMV if he wants to go the non-CMV way. The best way to find out is to ask the others that are doing the same thing. Ask more than one just to make sure you get a good understanding.
  11. mas
    mas Bobtail Member
    5
    Thanks for the responses.
    I guess this is my question, can I take my F250 and 24' tag trailer to a CDL school, do the walk around and the road test in that combination vehicle and then be cleared to drive the bigger truck and trailer with the same CDL? I know there is a "no tractor/trailer" restriction available in my state and the equipment I am going to drive in the near future isn't considered a tractor trailer anyway.
    Laws are confusing sometimes!
