Upgrading wheels on my truck
Discussion in 'Expediter and Hot Shot Trucking Forum' started by 24kHotshot, Jan 7, 2020.
  1. 24kHotshot
    24kHotshot Heavy Load Member
    801
    874
    Feb 19, 2019
    New York
    Would like some opinions.
    I'm looking into upgrading my truck's 17s to 19.5 with better tires with higher load ratings, as I understand all the DOT seems to care about is my registered weight and tire ratings.
    Current tires on the drives are rated to 12k between the 4. Set of 19.5 would reach 15k.
    Current tires are almost done after 40k miles, I'm told the 19.5s would run for much longer, is this true?
    Also, had a flat tire and no truckstop I could reach would work on 17 inch tires at all. Local shops didnt have enough room for me to get to with my truck/trailer or the equipment to lift a loaded truck/trailer.
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    A few things..
    It will change your gear ratio. If you have enough low gears to get rolling, you should be fine. Just know that it will effect MPG and put more strain on your motor if you stomp on it during take off.
    Tire life varies depending on loads, manufacturer and composition.
    Ride quality may also be affected. Admittedly, I don't know if your current setup is air ride or not.
  4. 24kHotshot
    801
    874
    Feb 19, 2019
    New York
    Current ratio is 4:10. I never stomp my truck. I prefer a slow roll up to speed. I baby my truck, goes in for inspection and maintenance every 10k miles. Truck isn't currently air ride but will be soon, kits are pretty affordable.
    I was going to sell my setup and go for a single axle semi and bigger trailer but I can't afford what I want and don't want what I can afford. Giving my current setup a few upgrades and will reconsider an upgrade in a year or two.
    Mike250rs Thanks this.
  5. Brandonpdx
    Brandonpdx Road Train Member
    4,541
    4,496
    Dec 27, 2007
    Elkhart, IN
    19.5 could be better in theory but you may not find that one to be a very sensible idea from a cost perspective. If you can find a good set of take-off steelies then maybe, but even the hub adapters are around $1000 for the set last I checked. I wouldn't do it TBH.
    I'm not terribly surprised the OEM tires would only last 40-50k. They are more of a ride comfort tire rather than a commercial duty tire that come on a new little truck. Check out Bridgestone's "Duravis" line and/or Michelin's "Rib" series tires in 17" and you will get double that easy if your alignment is set properly (have it checked when you put the new ones on anyway...). Also check into the Centramatic auto balancers for all 4 positions and get rid of the stick-on weights. They will help extend tire life and smooth the ride out. They are a little bit of an investment but worth it. I run a pair on my steer axle and will get the ones for the back at some point. Don't get the knockoffs either, get the real deal original ones. Some have had bad luck with the brand-X versions. Also you might get some better ride if you throw the OEM aluminum dually wheels on there if you just have the steel ones. Suspension will work better with less unsprung weight on it.
    The one nice thing about running a little truck is you can use the jack kit to R&R a spare tire yourself in a pinch if you really need too, like if a steer tire goes out on you. But if you are running top shelf rubber and checking the pressures that should not happen too often. With a big truck you are stuck waiting for help to show up because everything is too heavy and requires special tools.
    As far as your weight limitations the rear axle on that one is probably not rated for 15k anyway on your 3500. I have a Dana 80 under mine and I believe Dana themselves only rates it for 12k or so, while the tires are limited on mine to around 10k. 5500's are probably rated that high.
    Itsbrokeagain Thanks this.
  6. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    What size are your current tires? Most likely going to a set of 225/75/19.5’s wont change anything with your gearing or speedometer. You wont need any hub adapters ether. Search out your bolt pattern and ether American Force or Alcoa will have direct bolt on 19.5’s but you’ll most likely have to run a steel inner with an aluminum outer as the studs arent long enough. I have an F450 pickup that came with 10 lug 19.5’s factory. I have ruffly 100,000 miles on my hankook DH01’s on the rear axle and they are wearing flat and still have at lest 100,000 more in them. Granted I dont haul much of anything with it but its putting 550hp to the ground and Im not easy on the go pedal.
  7. Brandonpdx
    4,541
    4,496
    Dec 27, 2007
    Elkhart, IN
    Which transmission does your have? 68RFE or Aisin? 4.10 was a good call but a larger diameter tire will drop your RPMS and cause overdrive to lug down a little bit. Be a little careful with that one because it can throw your odometer accuracy off which could obviously be a concern for a commercial use vehicle. Have to do some more research on that one.
  8. 24kHotshot
    801
    874
    Feb 19, 2019
    New York
    Don't need adapters. Found 19.5 steelies that fit.
    The alignment is straight until i'm loaded heavy and then the steers go out of alignment. That's why I'm getting airbags so the truck will ride level when loaded.
    I had a leak that would empty 50% of the tire in about half a day and it was on the rear with a loaded trailer. I would have snapped the jack that came with the truck. I have a 20 ton jack I bought that could handle it but I didn't want to take off a wheel with a loaded trailer on it. Woke up early the next day when I was empty and swapped out the spare. I rather pay to have it done next time rather than waste my energy doing it myself before a long day on the road.
    Yea it isn't rated for 15k but to be honest sometimes I am a little past my rating no matter how I placed my load. Extra load rating on the tires can't be a bad thing. I'm aware that I'm killing the axle but sometime the load is worth it. These are bad times for light loads, the only way I hit my weekly mark is carrying heavy units.
  9. 24kHotshot
    801
    874
    Feb 19, 2019
    New York
    Currently 235/80/17s. Can't find any good rated tires for that size. Going to run steel all around. Not looking to be fancy.
  10. 24kHotshot
    801
    874
    Feb 19, 2019
    New York
    Aisin.
    Can you explain the odometer accuracy issues?
  11. Roberts450
    2,237
    3,638
    Feb 6, 2016
    Ok thats what I thought. The 235/80/17 are just under 32” tall and a 225/75-19.5 are just over 32” tall. So they will be a good replacement. The odo will be off just a little but not much.
    24kHotshot Thanks this.
