Upgrading your Engine from 395HP to 435HP, Thoughts?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Manny129, Jul 2, 2011.
  1. Manny129
    Manny129 Light Load Member
    150
    25
    Aug 16, 2010
    What you guys think? Good Idea or not? I have a Volvo D12D 395 HP. Pulling light a lot (30,000 or less). But when I cant find loads 30,000 or less, i'm stuck with 40,000 pounds or more. I don't want to kill my engine for an extra $300. So I think going to 435 HP will help. But, is it a good idea? Any problems in the future? MPG decrease? (Averaging 6.4 carrying 20,000)
    Here's the engine: http://www.wheelingtruck.com/pdf/D12D395_VN.pdf
  3. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    Depends on your gearing, type of trailer you pull and the terrain you drive.
  4. Manny129
    150
    25
    Aug 16, 2010
    Reefer, 10 Speed Eaton Fuller, East coast to west coast (NJ to AZ,TX,NV, AZ to East, Northeast to FL),
  5. Tightwad
    Tightwad Light Load Member
    69
    16
    Jul 2, 2011
    I think the move from 1450 lb-ft to 1550 lb-ft will make more difference. Its the power under the curve not the peak that makes the difference. I think it will improve the performance of the truck.
    I dont really know Volvos so I dont know what the differences are other than more fuel above 1100 rpm. One may have a better timing map which can effect fuel mileage. If you make use of the extra power all the time it will hurt fuel mileage. If you just use it to help reduce downshifts in pulls it may help.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    be carefull! 420 HP and higher D12D was with articulated pistons, 380-400 HP engines may be with cast aluminium pistons and check it first.
    If you upgrade ECM rating up to 430-460 HP cast pistons will be damaged with exessive heat in the first trip, especially in mountains ore if you haul a lot of stuff in trailer. So check what pistons you have by VIN ore engine number you have!
    When I was young and silly I did D12A reprogranning from 380 to 420 and 460 HP and got this problem, and now I know that pistons and piston cooling springles must be done!
  7. Manny129
    150
    25
    Aug 16, 2010
    Thanks I will check that now.
  8. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    40 horsepower? Why even bother?
    Logan76 Thanks this.
  9. Tightwad
    69
    16
    Jul 2, 2011
    Its not for the 40 hp its for the 100 lb-ft of torque.
