upping horse power and torque. can i do it?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kenwortht660, Jun 28, 2008.
  1. kenwortht660
    kenwortht660 Bobtail Member
    40
    Oakland, CA
    i am about to buy a truck with a cummins isx 455 ST with 1750/1450 smart torque. can i have cummins up the horse power to 525 and torque to 1850/1550?
    I was told by a dealer that I could do this but I do not know if it is true. He said that all the ISX engines are the same size block engine. The torque and horsepower are just ratings could be upped by cummins, but the warranty would have to be upped if you increase the power rating. Is this true?
  3. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    I don't know the isx but the N14 could be turned to 500 by changing setting. to goto 525 you had to change parts. turbo and injectors if I remember right. that last 25hp was expensive
  4. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    Yeah but the 200lb of torque was worth it, in my opinion it was more than 25hp in reality and if you had a 460 it would go to 525hp.
    Not sure on isx, but if you can dont mess with the smart torque crap, just set it to a straight 525/1850.
  5. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    I almost bought an early ninties binder cabover that had a 435 N14 originally. when they overhauled it they set it to 500. They guy tld me they said to go to 525 they needed to start throwing parts at it. that is the extent of my knowledge so take it for what it's worth. I never even looked at a cummins before last year
  6. 550hpW900L
    1,874
    1,090
    Jan 29, 2008
    norcal
    Yeah the 435s could only go to 500 without a turbo and injector change, i ment 460hp but typed 360, sorry.
  7. BrainHurtz
    BrainHurtz Light Load Member
    245
    57
    Jun 24, 2008
    Terre Haute, In
    The answer is yes and no. If it was a major bump the drivetrain might not be spec'd to handle it and the dealer should say no. But unless somebody was really cost concious at the time they had the truck built there shouldn't be a problem going from 1750 to 1850.
    Naturally the 600HP/2050ftlb ISX rating is a totally different story.
    QuietStorm Thanks this.
  8. DarkKnight
    DarkKnight Bobtail Member
    32
    Jun 27, 2008
    Gotham City
    It is easy.... You can even do it yourself go to the Cummins website and download Powerspec, it is free. Then buy a cable from Cummins for about 700 bucks and change the parameters from your laptop.
  9. pathfinder
    pathfinder Medium Load Member
    410
    617
    Aug 25, 2007
    central,MN
    $700 for a cable?! Ouch! It better be easy after that much coin!:biggrin_2551:
  10. KingRaheem
    KingRaheem Bobtail Member
    39
    5
    Jul 4, 2018
    Can the 485hp 1850 be bumped up to 2050? Money not an issue what would it take to do it?
  11. QuietStorm
    QuietStorm Heavy Load Member
    899
    1,416
    Dec 11, 2016
    This is basically the answer, just find out if the same spec parts are used for the higher hp and torque or not. Sometimes they use different injectors, etc and if you don't have the right parts that can handle the pressures you might have issues.
