Urgent help - Is a 3-7-7-3 split sleeper birth possible or are only 3-7-3-7 allowed?
Discussion in 'Questions From New Drivers' started by MaineRoad96, Jun 17, 2022.
  1. MaineRoad96
    MaineRoad96 Light Load Member
    61
    99
    Apr 5, 2022
    I need to start driving ASAP so I would really appreciate it if you guys could answer as quick as possible if you know!
    Are 3-7-7-3 splits possible?
    I'm on a tight load I think I might've just screwed myself. Times are in military time. I'm not concerned with HOW MUCH time I'll be gaining back (receiver and shipper are close to each other so I'm guaranteed enough time to make it from receiver to shipper after spending 2-3 hours at the shipper so I'm not worried about that).
    I'm ONLY concerned as to whether or not I'll get time back on that last 3 of the 3-7-7-3 split or if I'm essentially going to have to do a 3-7-7-7 split. So all the on duty/off duty time in between shifts is irrelevant and I'm not going to include them to make it simple. Times are given in central time zone.
    June 16
    A. Normal 10 hour break
    SB - 0130
    On Duty - 1147
    B. 3-7-7-3
    SB - 1810
    On Duty - 2041
    Duration - 2 hours 31 minutes
    June 17
    C. 3-7-7-3
    SB - 0156
    On Duty - 1035
    Duration - 8 hours 39 minutes
    D. 3-7-7-3
    SB - 1332
    And this is where I'm at now guys. So is the 3-7-7-3 split possible and if so, at what time can I start driving right now for my split to be ok? Can I do it at 2032 here in a few minutes or do I need to wait later based on my last split sleeper period?
    I have thoroughly confused myself and I could really use your help. I don't really want to wait the full 10 hours because I think I'm going to get too tired to complete the whole drive so I really want to start driving in 5 minutes if possible.
    Boondock Thanks this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,726
    18,548
    Nov 1, 2010
    Burnsville, MN
    Well, that was 19 minutes ago.
    What did you do?
    And is all the stress you are putting yourself through actually worth it in the long run?
  4. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Rest easy. Sleep does a body good. Get some you, I, and the rest will rest easy knowing a rested trucker driver is behind the wheel.
  5. Numb
    Numb Crusty Curmudgeon
    4,124
    9,567
    Jan 30, 2012
    Charlotte, N.Carolina
    :confused:o_O:confused: and that's why I never did the split stuff.
    it can get confusing if you're tired and you can screw it all up.
  6. austinmike
    108,449
    Same here - when I was still using paper, sometimes it was all I could do to fill out the dang thing and come up with 24 hrs -
  7. roundhouse
    roundhouse Road Train Member
    3,179
    7,232
    Jul 11, 2018
    With the papers I used to do the 5 on 4 off 5 on 4 off 5 on , 9 off .
    Actually i just drove the 14 hours straight , to get from Biloxi to Chicago non stop , but the log book was as I described .
    Bean Jr., SoCalKid, Boondock and 4 others Thank this.
  8. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,032
    Dec 31, 2010
    Washington, PA
    The title alone had me confused.
  9. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    I have run splits back to back for several days. To the best of my knowledge, as long as the rules are properly adhered to, no issues with running splits for multiple days. I've probably done the 3. 7. 7. 3. Split, but can't remember a specific instance.
    Splits:
    1. Must have at least one portion that is 7 hours or more continuous in sleeper berth.
    2. The other portion has to be at least 2 hours of off duty or sleeper berth.
    3.. Both split portions must add up to at least 10 hours. Order taken doesn't matter.
    A common mistake made by many is thinking a split will allow them more hours, it doesn't. It is simply a way to have more flexibility with the hours you have. It makes things easier to fit into your 14 hour driving window since it allows you to be able to extend that window.
    Also, if you take the shorter off duty portion, but afterward take a full 10 hour break. You must still have the longer portion (between 7 and 8 hours continuous in sleeper berth where both portions add up to at least 10 hours) as part of that 10 hour break. Although a mute point, IMHO, without showing BOTH portions of the split, you are technically in violation.
    There, clear as mud!
    Bean Jr., Boondock and baha Thank this.
  10. Wasted Thyme
    7,729
    38,304
    Jan 27, 2020
    GOAT watching
    In general it doesn't matter. It can be 7/3 or 3/7.
    Either way. They don't give you time back. They just pause the clock. So OPs question is pointless. If he is just trying to drive farther than he has time.
  11. Geekonthestreet
    Geekonthestreet Medium Load Member
    344
    587
    Jun 27, 2021
    Chicago
    The only time to abuse split sleeper IMO is if you get delayed for maintenance or some weird road closure.
    Boondock and alds Thank this.
