US1 from Baltimore to Trenton to avoid tolls?
Discussion in 'Questions From New Drivers' started by Mmuzic12, Apr 17, 2021.
  1. Mmuzic12
    Mmuzic12 Bobtail Member
    15
    13
    Dec 17, 2020
    Has anyone taken US1 from Baltimore to Trenton, NJ? Looks like a decent bypass route for avoiding tolls if you have the extra time to drive. However, I heard there may be a truck restriction at some point. The Rand McNally Motor Carriers Atlas shows it as a truck route. However my Garmin GPS keeps forcing me on the NJ turnpike, I had to drop like 12 pins on US1 to keep it on track (not that I trust it 100% anyway). Figured it doesn’t hurt to ask. Thanks in advance if you take time and reply!
    slow.rider Thanks this.
  3. Mmuzic12
    15
    13
    Dec 17, 2020
    I also have the AllStays truck and travel app and looks like some questionable low clearance areas on US1 there
  4. bad-luck
    bad-luck Road Train Member
    3,300
    6,064
    Nov 16, 2013
    Baltimore, Maryland
    You would not want to take that route. 1st its illegal to take a 53' trailer over the Conowingo dam in Maryland, I recommendyou goingover the dam at night only. 2nd you will hit a ton of lights coming out of Baltimore and in Pennsylvania from Rt 202 all the way through Philly. I recommend taking 95.
    spindrift, Mmuzic12 and slow.rider Thank this.
  5. Mmuzic12
    15
    13
    Dec 17, 2020
    Copy that, thanks for the advice. I’ll definitely stay on 95
  6. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Since when does Route One enter Trenton Maine?
    (rhetorical)
  7. Mmuzic12
    15
    13
    Dec 17, 2020
    Trenton, New Jersey. Rt 1 interchanges at 695 on north side of Baltimore and goes up through Philadelphia and Trenton. Keeps going but I stopped at Trenton
  8. lovesthedrive
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    I realiized that. hence why I said "(rhetorical)" meaning i knew the answer and didnt need a response
    Mmuzic12 Thanks this.
  9. Jacoooooooo
    Jacoooooooo Heavy Load Member
    747
    1,054
    Oct 20, 2013
    To Trenton go 95. If you go to NYC go thru Lancaster. Either way you go, make sure to charge extra for that route.
