Useful links for belts/hoses info
Discussion in 'Peterbilt Forum' started by The Truckist, Sep 17, 2010.
  1. The Truckist
    The Truckist Medium Load Member
    342
    245
    Sep 11, 2010
    This may be of interest to some O/O's around here and it does not just apply to Peterbilt. I was not sure where to post it and tried to utilize the proper wording if somebody used the SEARCH feature in the forums looking for belt info, this might help them. It kinda surprised me that the web developers of the sites below had initiated such a service, especially for the heavy duty market.
    Fan belts, whether serpentine or otherwise, can be troublesome at times to size and locate. I like to keep a record of part numbers for all the various accessories, belts, components when I can actually read them off the original. I got most of that info when this latest truck was put into service for future use but the original belt numbers were not legible even when new. You may have the good/bad fortune of hearing that strange thud under the hood and begin to wonder "What was that?" Good being the part that you are not going to have to take out your trusty pocket knife and cut the belt off because time, age and centrifugal force already done half the job for you. Bad being the part where you gotta do it now, on the side of the boulevard...in the desert...at night...kickin' the snakes & porcupines out of the way. Preventive maintenance is a good thing.
    These 2 manufacturers sites below will allow you to enter the 17-digit VIN to get a display of the belt part numbers and hose information. DAYCO belts website also brings up part numbers for the belt tensioners for fan/alternator/air conditioning applications, where applicable. GATES may do so as well. I know that the GATES site also gives the original equipment manufacturer's part numbers as well as their own. And I'm pretty sure they offer a parts number cross-reference for other numbers. I just found it to be helpful and thought to myself, as you probably will..."Why didn't this get done long ago?" Calling around to my local parts guys today, I mentioned this about one of the websites and my counter guy said "Wow! I have been waiting for Peterbilt to do this for years...make my job a lot easier!" I had to inform him that Peterbilt or Paccar didn't do it...it was the belt/hose manufacturers sites.
    Anyway...here are the links if I am able to post them:
    GATES HEAVY DUTY VIN DECIPHER TOOL
    DAYCO VIN DECIPHER TOOL
    The DAYCO site will require you to select "Heavy Duty" if searching for your big rig. Both sites will also have Parts locaters using Zip codes, addresses, etc however I noticed many Advance Auto & AutoZones listed for sellers. I know these places won't carry or stock such heavy duty items but I am not sure if they can indeed order them. Anyway, it gives you something to go on when checking out your favorite Fleet Pride or TruckPro. In the past, an inquiry about fan belts always ended up with "bring in the belt and we'll try to match it up". That used to work years ago...and still does in some cases, but these 6-12 rib serpentine belts & others get a little aggravating to source if you waited too long to change 'em.
    Just to be sure, I called my Pete store and asked my parts guy to give me the belt numbers using the last 6 of my VIN. He gave me the original Pete part numbers, which coincided with the GATES site VIN look-up for my truck.
    No big deal but maybe it'll make somebody's life a little easier. Check them belts for cracks and change 'em if needed. My 12 rib serpentine belt for an ISX fan belt was only $35.25 & the A/C 6 rib was $25.72. Yep, that's a lot more than the ol' $4.50 NAPA Gold v-belt but just like that leather belt I used when I was 17 years old...neither one of them will fit around the thang they need to fit around. :)
    gonzo01 and black_dog106 Thank this.
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Thanks Truckist...:biggrin_25514:
    Had a belt break one time that was nearly new.
    These things never happen at a convenient time or location. I started carrying a spare set of belts after that incident.
    The Truckist Thanks this.
  4. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    one nice trick i have up my sleeve---had the ac compressor go out while on the road--had to get a call out--mech short belted it to bypass compressor and keep alt going--the cost was $5oo---so now i always keep that short belt with me in spares--i can drive without ac--but not without alternator
  5. The Truckist
    342
    245
    Sep 11, 2010
    Thanks back at ya, Dog. Yeah it's hard to keep spare everything in your truck just in case but belts don't take a lot of room.
  6. black_dog106
    1,786
    1,666
    Mar 29, 2009
    MA
    I carry to much with me, but it sure is cheaper than road service or trying to find small parts. As i said before, extra belts, air line fittings, caps and plugs for most lines on truck. Caging bolts, fuel filters(during winter), jumper cables. The list goes on. As i said, to much stuff but it all gets used eventually. Many times it is used on someone elses truck...
  7. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    you sond like me black dog----i pulled wrenches for about 25 yrs so i have a good idea of what might go pop while on the road--i found if you hit the bone yard behind the shop it is treasure trove for clamps/hoses all the goodys you might need---i had so much stuff in the classic--when i moved out i had to chuck some cause i couldnt fit it all in my tahoe
  8. Nless81
    Nless81 Bobtail Member
    17
    Jul 20, 2015
    West Texas
    Have any of you guys had success cross referencing an alternator? In particular a reefer alternator?
