I was called in for ore employment drug test & physical for holland,I might possibly have the job,it will be on the limehaul out of ellenwood ga,was wondering if anybody works here and could give me info on what to expect
Usf holland Need info
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by Ga400, Mar 12, 2013.
if you get hired for line haul you will be on probation for 30 calendar days you will run open board ( or wild , however you want tot phrase it) you will run a lot of miles and sleep in the hotels, more than likely go out sunday or monday night and wont be back at your home terminal till sat morning, once you finihs your probation chances are that you are going to get bumped off by a senior man and you will be forced on a short run bid, ( less money, less miles , more work on the dock )
hope that helps -
I just started last week. The probation is 30 calendar days? A friend said it was 30 working days
My understanding is its 30 calendar days . It could be different in the south . Better ask your union steward . They are on your side and will answer all questions you may have
minitman Thanks this.
