Using a Johnson Bar Brake with Jake Brake on hills
Discussion in 'Questions From New Drivers' started by bob888, Jul 28, 2013.
  1. bob888
    bob888 Light Load Member
    155
    9
    Feb 17, 2012
    idaho
    I was in an older Kenworth the other day and used the johnson brake set at about 20 on the dial to slow the full load downhill. The jake was on the most setting and the rig slowed well enough. 80K lbs. I had never used one before and the other driver showed me how he does it.
    I notice on newer trucks the johnson brake is just a handle that springs back to 0 when you take your hand off it.This older one was set
    by lowering it and the dial showed the level. I didnt ask the guy but can you use this device routinely as a brake on hills along with the jake
    and what info is useful regarding this thing...??
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    You do realize that hand valve only applies trl brakes. Also if not careful you will smoke trl brakes and or catch them on fire. I use it all the time on my trk as i pull company trailers and wear out their brakes. Mine on my new kw stays where i put it. Also good for checking trl brakes for leaks on service side of brake chambers. Push in red trl supply valve then pull down handle and walk back to rear of trl and check brake lights and for air leaks. Also good for sliding stubborn tandems with out much wear on clutch. Release your slider pins and roll along in first gear at an idle push in clutch and pull down on handle tandems slide. Don't use this method for trying to slide only one or 2 holes.
    daddyhusky and toostroked Thank this.
  4. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    The distribution of air to brakes on a semi trailer is designed such that about "55-60%" of the air applied (with foot pedal) will go to the trailer. if you go down the hill with the trailer brakes ONLY ("johnson brake") being utilized, they are going to get hot. And when you find yourself unable to keep the load in a controlled descent, you will then use the foot pedal, you're still going to be asking the trailer to do much of the work as by design but they will be too hot to provide much benefit and you will have to apply a LOT of air to make the tractor brakes try and play catch-up and do all the work because the trailer brakes are essentially useless at that point. Hope that I made a little bit of sense with reply.
    TonyPDX, Sailguy, 25(2)+2 and 3 others Thank this.
  5. daddyhusky
    daddyhusky Light Load Member
    80
    53
    Jan 23, 2009
    Atlanta, GA
    Johnson brakes, I am told, are also good for straightening out when you start to jacknife in slick conditions. A little pressure to the trailer brakes slows it down while the tractor goes forward getting you straight- of course if it is pure ice it won't help much. No one ever wants to look in their mirror and see their trailer swinging around.
  6. morr2fab
    morr2fab Medium Load Member
    338
    110
    Oct 3, 2012
    In my world it's called the "Trolly Brake". I was told to Never use it to help stop the truck except in an emergency, as in the truck brakes dont work. You will over work the trailer brakes using it the way you are. Over heated brakes wont stop a truck very well.
  7. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    you get into a habit if using the handle brake only. then what ydou going to do when you brain fart in an emergency and reach for the handle instead of the foot.
    now you've hit the car in front of you. you killed the kids. and spent the rest of your with 2 LOUSY hots and a cot behind bars.
    the trailer brake is for emergencies ONLY. the pedal is for full time use. anyone that teaches you to use the trolley cuz they do it. is a fool themselves.
    you've got 10 brakes to slow you down. 6 of them aren't there to be collecting dust while the other 4 burn out.
    you don't use the emergency brake handle in your car. why would you use it on a 80,000 lb. rig?
    i've also noticed my jakes get weak as the overhead wears down. they get strong again when the overhead is done. you work for a company that doesn't do routine maintanace. soon you won't have jakes to help you out with that trolley brake.
    Joetro, TonyPDX and toostroked Thank this.
  8. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    That makes a lot of sense. Although I am guilty of doing this as well. Never have I used that much air though. My gauge reads in increments of 15 psi and I have never hit the 15psi mark coming down a hill. I'd estimate the 8-10pai range on a down grade. My opinion on the matter you will usually have to use your brakes some on a down grade, if you've put 25psi back to them 5 or more times in a mile you're in to tall of gear. Jake on 3 if I'm in the right gear and the safe speed is 35 I can leave the trolley set at under that 15psi mark and never get above my safe speed. I have never smoked a set of brakes, never had a set get to terribly hot. Not to say that it won't happen someday but it hasn't happened yet. Sadly I don't believe in what that stupid book tells me which is hit your brakes to 5mph below safe speed release and repeat every 3 seconds I'd be out of air in a mile doing that crap. Brakes would probably be hotter at the bottom of the pass than doing it the way I do it now too. Just my .02 on the situation. I don't johnny bar my brakes to stop normally only time I use it is on a grade or testing trailer brakes. I do see you're point though with that much pressure going back there it'll fry them trailer brakes if he his a 3 or 4 mile grade.
  9. STexan
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Some figure their not their brakes, so what the h**l. Furthermore, when I smell burning asbestos, it makes me ill regardless who's it is. Just makes me nervous somebody is pushing their limits like that. And a lot of times it not so much the braking technique implemented but rather perhaps a single brake out of adjustment or defective and being applied way too hard in relation to the others.
  10. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    It's amazing to me that this is even a discussion????? The guy who showed you how to do this is an idiot and....,.this is why companies apparently aren't putting trolly bars in company trucks anymore (so I've been told). I believe, but could be wrong, that this is even illegal? A Johnson bar is used to do a tug test or to check service brakes on a trailer. Could all this other stuff I.e. braking on a mountain be done?? Sure but that doesn't make it a good idea. It's this reason that fleets have to dummy proof company trucks anymore. Too many dummies behind the wheel.
    Joetro Thanks this.
  11. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    how do you think trucks got down steep grades before every truck had jacob brakes or retarders in them. the real problem starts when a young driver machine guns off the top of a grade to fast. there is nothing wrong using the johnson bar to slow you down a little on a grade if used in moderation. have said this before dont put your life in danger for a $3.00 jake brake switch made in china. you see drivers do it all the time starting down sherman at 75 because they are lite. be careful out there
    'olhand Thanks this.
