USING SHOP AIR FOR BRAKE INSPECTION?
Discussion in 'Questions From New Drivers' started by mhs2260, Jan 29, 2019.
  1. mhs2260
    mhs2260 Bobtail Member
    Is using the air compressor from the shop for Brake inspection the same as a trucks air compressor?
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Yes it is, The only difference would be your not doing a leak down test on the air system for the truck. On second thought you can even do that if attach a gauge to it to check for air loss on the system.
  4. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    If you are doing a DOT inspection, No.
    Bean Jr. Thanks this.
  5. rolls canardly
    rolls canardly Road Train Member
    1,611
    3,814
    Feb 7, 2009
    mt. pocono. pa.
    Depends on what shop air is.
    If it's like 160 or some crazy PSI like I have, not good, you'll break something.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    It's cheating. Put that airhose down lolz.
    You really don't know what sort of monster shop machine is feeding it. You would break something somewhere me thinks. I remember shops capable of moving enough PSI to turn over steam engines.
    rabbiporkchop Thanks this.
  7. mhs2260
    If the Shop Air compressor is runnin between 160-200 PSI would it cause more push rod travel ?
  8. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    No it would cause #### to blow up.
    rabbiporkchop, Bean Jr. and whosfate Thank this.
  9. rolls canardly
    1,611
    3,814
    Feb 7, 2009
    mt. pocono. pa.
    Possibly.
    When you dig it out of the 6 inches of asphalt it was blown into,
    measure it, and compare the results against length of a new one.
    D.Tibbitt and Farmerbob1 Thank this.
  10. REALITY098765
    REALITY098765 Road Train Member
    1,496
    1,329
    Sep 17, 2017
    This is the correct answer and anybody that says otherwise is confused. IMO.
  11. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    For measuring brake chamber stroke? Shop air shouldn’t be more than 120 psi (you can verify your shop’s air pressure with even a simple tire pressure gauge, but you might have to rig up a fittting to make it work.
    I can see where it would be useful for checking brake stroke for something which isn’t a DOT inspection, but I’d go through the quick release or relay valve (whichever one it uses), rather than directly to the chamber. You take a simple trigger actuated air blower and make it work.
