Using up a lot of water
Discussion in 'Peterbilt Forum' started by law3tkm, Jun 7, 2012.
  1. law3tkm
    law3tkm Bobtail Member
    7
    Cuero, TX
    My truck is using up about a gallon of water a week. Any ideas why? It's an '01 379 with a 475 cat
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    If it's not a noticeable leak it might be going out the exhaust because of a bad head gasket or cracked head. Pull your dipstick and see if you notice any moisture. Look and see if you see any leak tracks behind the water pump pulley area. If you can't find the problem you can get a smoke test done on the cooling system. It'll let you know where it's leaking.
  4. Turbo55
    Turbo55 Bobtail Member
    9
    put a rag over the stack for a few minutes, if it smells like antifreeze. probably a head gasket
  5. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    Check for external leaks. If its going out the exhaust you can generally smell it or see the smoke. Check your trans level if you have a oil to water cooler.
  6. Flip Flops
    Flip Flops Medium Load Member
    603
    304
    Jun 1, 2012
    The Left Lane..
    I'm with the others its going up the stacks more than likely, I had the same problem with a C-15......It was a cracked head..
