using windshield to mount camera and gps question .
Discussion in 'Questions From New Drivers' started by evd, May 25, 2014.
  1. evd
    evd Light Load Member
    130
    90
    Apr 23, 2012
    Reading PA
    can you get a ticket for having both ?
  3. stlvance
    stlvance Medium Load Member
    578
    259
    Dec 20, 2011
    st louis MO
    As long as they are not blocking your view nope. Well i havent yet.my cam is top middle of pass side and the gps is top corner by the a piller driveside
    evd Thanks this.
  4. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    I believe the rule is there cannot be anything lower than the area the visor covers or anywhere in the area swept by the windshield wipers, however...
    evd Thanks this.
  5. MsJamie
    MsJamie Road Train Member
    Possibly. CA and MN have a ton of restrictions. Both were illegal in CA until recently.
    The GPS has to be mounted on the lower corner of the windshield (near the door). Put it in the lower center, and you can be ticketed. Stlvance can be ticketed for having his mounted too high.
    The dash cam has to be in the upper center, where the rear view mirror would normally be. Fortunately, this is the optimal location for one. The pain is that you can't have the power wire hanging down...
    CA: http://www.dmv.ca.gov/pubs/vctop/d12/vc26708.htm
    MN: https://www.revisor.mn.gov/statutes/?id=169.71
    I don't know if either is a stoppable offense by itself. However, you can certainly be cited during a DOT inspection, and DOT doesn't need a reason to do a roadside inspection.
    Then again, there are states where you can get cited for having a "tuned up" CB or 10 meter rig in your truck without a ham radio license, but I have yet to hear anyone get hit with that one.
    evd Thanks this.
  6. rank
    rank Road Train Member
    9,918
    113,501
    Feb 11, 2010
    I've had a net book wit ha 10" screen mounted on the dash above the toggles in my '98 T800 for 7 years (probably 10-15 inspections in NY, ON, QC). Once I had a NY DOT ask me if I was watching movies but other than that I have had not a single comment.
    evd Thanks this.
  7. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    in the 70s was ticketed at little chute scale in wisc, for obstruction of vision. had one of those little waving hands in the rider side windshield,scale master told me he gave me a brake because my cb was also higher than 4 inches above the dash. those type of things have been going on for ever,now the enforcement officers complain drivers dont like them. there is a line between enforcement and harassment and a lot of officer cross that line in the name of safety. be safe out there
    evd Thanks this.
  8. CellNet
    CellNet Light Load Member
    206
    82
    Jun 19, 2011
    Chicago IL
    Watch out guys Missouri will give you violation even for GPS on windshield, so i took it off and now is attached to the dash!
    evd Thanks this.
  9. 201
    201 Road Train Member
    12,272
    25,055
    Apr 16, 2014
    high plains colorado
    Hi j, That scale was the BIGGEST pain in the butt, always open and I believe it's still there NB, but they did away with the SB one. I would religiously go around it (55 N or 47 N to 54 E into Green Bay).
  10. stlvance
    578
    259
    Dec 20, 2011
    st louis MO
    Thanks msjamie for the info but oddly enough i had both units mounted when truckee pulled me in the garage to share the donuts. Nothing said about either one. And as im not going back into that state anymore i guess its one of those officer discretion rules lol im sure other states have something similar but so far nothings been said about it in reading those rules the gps lower edge is higher then the lower edge of the sunvisor.
    Might be why cali overlooked it.
  11. evd
    130
    90
    Apr 23, 2012
    Reading PA
    thanks guys ill be driving north east cost .
