Valve ID???? Help.
Discussion in 'Kenworth Forum' started by KWT800, Aug 14, 2014.
  1. KWT800
    KWT800 Bobtail Member
    Hi everyone. i'm new to the forum. I thought this would be as good a place as any to help id this valve that is leaking on Dad's truck. it is an 89 KW T800. This valve comes out of the tank and i believe the air line goes back to the ride height valve above the rear axles. so what would this be and where would i get a new one? KW.jpg KW2.jpg Thanks!!
  3. CellNet
    CellNet Light Load Member
    206
    82
    Jun 19, 2011
    Chicago IL
    Hi, just take it off and go to the closest dealers, they should have it or at least order it.
  4. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    That is a pressure protection valve, meant to stop air flow if a line breaks. For the suspension they are normally a 90 psi rating, meaning it will open about 90 psi and close below that, to save air for the braking system.
