Valve under brake pedal leaking. 03’ International 9900I
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dadetrucking305, Sep 1, 2024.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    Hi! I have an 03’ International 9900I that has a leak from the valve that goes underneath the brake pedal. I recently replaced it due to not being able to build up air past 30 psi. When I did replace it it did not leak for the first day but it’s been leaking ever since. What do I need to look at? TIA
  3. Inderjit
    Inderjit Heavy Load Member
    719
    707
    Sep 17, 2017
    Does it leak when the brake is applied or when released?
    Is it leaking out the exhaust on the bottom of the valve?
    Dadetrucking305 Thanks this.
  4. Dadetrucking305
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    Both ways.
    Yes out of the exhaust.
  5. Inderjit
    719
    707
    Sep 17, 2017
    If it leaks out the exhaust when the pedal is not depressed it can be a back feed from a valve downstream. If it leaks out the exhaust with the pedal depressed it is usually the treadle valve that's faulty. I suspect that the new valve is faulty or a piece of debris found its way inside the valve when you were replacing it.
    Bean Jr. and Dadetrucking305 Thank this.
  6. Dadetrucking305
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    You can hear it just pissing out of the exhaust with the truck off.
  7. Heavyd
    Heavyd Road Train Member
    7,754
    6,189
    Feb 4, 2009
    Take off all your delivery lines one by one to see if any of them have air back feeding. Air back feeding from another valve will leak right out of the exhaust of this one, leading to replacing this valve for nothing.
  8. Dadetrucking305
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    How many valves are there on a 9900I? I know the one up on the firewall and also the one all the way at the back of the frame that’s square.
  9. Heavyd
    7,754
    6,189
    Feb 4, 2009
    Another valve that could be back feeding up a signal line is a rear relay valve. This will be leaking back up a green line if that was the case.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,429
    6,465
    Aug 26, 2014
    Maybe take the drain valves out of the air tanks and see if one is full off rust. I replaced a couple of leveling valves and foot valves in one because of that.
  11. BoxCarKidd
    4,429
    6,465
    Aug 26, 2014
    I just stuck a pencil magnet up in them and a ball of rust came back.
