van to tanker-advice
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by noguns3, Aug 5, 2013.
  1. noguns3
    noguns3 Light Load Member
    52
    13
    Jan 7, 2007
    Minnetonka, MN
    I am an owner op. switching from van to smooth bore food tanker. Any advice or helpful hints to help the transition go smooth? 19 Years driving experience, just new to tanks. Thanks in advance for the help.
    Chinatown Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    74,678
    169,816
    Aug 28, 2011
    Henderson, NV & Orient
    Something simple; get some good hearing protection. I bought mine at a gun store; they're like plastic ear muffs. There's some high pitched noises & some you may not even notice from pumps. It's easy to develop serious tinnitus; there is no cure and you live with it 24/7. I know; I have it.
    Beau3210 Thanks this.
  4. Numb
    Numb Crusty Curmudgeon
    4,050
    9,280
    Jan 30, 2012
    Charlotte, N.Carolina
    yes, tinnitus is a real pain. I've had for a number yrs.
    your going to have to relearn your driving skills. lol
    I'd been driving for 15yrs, when I went to tankers for a few yrs.
    the liquid moving around can really through you off.
    it can actually move the truck around on snowy roads.
    or roll you over in a curve.
    Le Cou Rouge Thanks this.
  5. 900,000-tons-of-steel
    900,000-tons-of-steel Road Train Member
    1,511
    896
    Aug 17, 2012
    Florida
    Good advice both from China and Numb.
    That surge can really through ya' around when you're first starting out. You'll swear you're being pulled/forced off the road at times. I remember before I began hauling product other than fuel (fuel has adequate baffling, most other stuff does not) I was prepared for the back-to-front surge but wasn't at all aware of that side-to-side pull that we experience. You'll get used to it. The longer you do it safely the better you'll become. Forget everything you know about vans. This is a whole new world. Drive slow and watch those curves.
  6. wis bang
    wis bang Road Train Member
    3,386
    3,977
    Jan 12, 2011
    Levittown, PA
    Easy & smoothe makes your day. rule of thump for Exit ramps is 1/2 the posted ramp speed; kinda keeps all the wheels on the road!
  7. noguns3
    52
    13
    Jan 7, 2007
    Minnetonka, MN
    Thanks for the replies. I appreciate them. Keep em coming.
  8. Dieselgeek
    Dieselgeek Medium Load Member
    427
    209
    Nov 25, 2012
    Minnesota
    Noguns, I was born and raised in Minnetonka...
  9. Beau3210
    Beau3210 Light Load Member
    72
    35
    May 3, 2013
    FL
    Although I've only been pulling tankers about 4 weeks now I found (learned) that when upshifting with a smoothbore, gently apply a little pressure to the throttle until you "feel" the liquid is at the rear of the tank then give it more throttle. It helps to prevent those sudden and often rude 'jerks'. Like wis bang said, smooth and easy is the name of the game, keep the liquid happy.
    Fuel hauling is the best so far. Love those baffled tanks!
  10. Flatbedder73
    Flatbedder73 Medium Load Member
    464
    354
    Dec 30, 2012
    Langhorne, PA
    i posted a thread entitled "surge control." Check it out, may help you figure it out.....and keep your braking steady. Welcome!
  11. Ridgeline
    22,370
    116,061
