van vs flat, or run both?
Discussion in 'Ask An Owner Operator' started by Trugo, Oct 5, 2018.
  1. Trugo
    Trugo Light Load Member
    71
    50
    Dec 8, 2015
    Im wondering if there are any opinions on this.
    Right now im running a 5 ton truck with a 26ft dry box. I can haul about 16,000lbs max with the setup. I work Southern Ontario, Canada based out of the Toronto area. I get work off a load board and also repeat customers. Its not bad, Im profitable and having fun. Theres plenty work. Some days its nothing but cheap freight but other days are good and sometimes I can find expedite loads that pay well, especially if its odd hours or odd locations. I can gross $10,000-12,000 per month doing this.
    But, I see alot of stuff on the board for flatbeds. For example, 10,000 lbs 10 feet 200 miles. Im wondering if profitability could grow in the flatbed business. I could ditch the box and put a deck on the truck and get some used flatbed gear.
    Anyone tried both? Would it be worthwhile to switch to flats or stick out the van business? One thing pulling me to flats is the increased skill and knowledge to be learned which may help the business down the line. But the van stuff is easy, skids, and theres tons of freight all the time.
  3. Rideandrepair
    17,357
    56,318
    Aug 8, 2015
    Hell if I know. How bout a curtain on one side? For offloading w/o dock? That could be your niche best of both worlds. They don’t call me idea man for nothing!!!
    whoopNride Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,568
    13,293
    Jul 6, 2009
    I think it would be tough to haul van freight on a flat.
    Maybe pull a flat behind box.
  5. HillbillyDeluxeTruck
    5,934
    30,339
    Mar 3, 2013
    San Antone
    I used to run hotshot for a guy in Houston that runs some straight trucks upto 52k gvw. He does a lot of local and regional and has been doing it for years now so I assume he's profitable.
    The only flatbeds I know are 53ft long.
  6. GreenPete359
    GreenPete359 Road Train Member
    2,152
    5,101
    Oct 21, 2017
    Driving my recliner
    26’ box. So you’re in a class 7 truck right? If you don’t have a lift gate, get yourself a flatbed to pull behind you. A 25-30’ eagerbeaver or something along them lines. You can pull equipment or regular flatbed freight.
