variable rate turbos?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by fmrbydaytkrbynight, Apr 30, 2007.
  1. fmrbydaytkrbynight
    fmrbydaytkrbynight Bobtail Member
    43
    Apr 27, 2007
    Texas
    just out of curiousity, do any of the newer trucks coming with variable rate turbos, and i'm not talking about variable waste gates? Myjohn deere service man claims that the new tractors have turbos with fins that actually chnge in angles according to engine needs for power and efficiency. Iwas just wondering if trucks were using this type of turbo, and how they are holding up.
  3. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,908
    12,210
    Sep 17, 2006
    WY
    Variable vein turbos is some thing Ford tried on the 6.0L Powserstroke with disastrous results when it comes to warranty costs.
    I don't know of any big trucks that use them.
  4. Burky
    Burky Road Train Member
    A great many of the newer trucks are using them. Basically, they change the blade angles to be more effective at various rpm ranges, and the main reason for doing this is to improve the emmisions of the engine as the engine spools up in rpm. If you look at newer trucks, you will see that there is what looks like a vacuum dashpot on the side of the turbo that operates the variable vane feature. It also involves sensors and software involving the fuel controls, so it's not something that could be retrofitted to an older engine.
  5. vegetto
    vegetto Bobtail Member
    20
    5
    Dec 14, 2006
    I know the new '07 Cat and Cummins don't adjust boost by adjusting the fins. They adjust boost by sliding a ring over the turbine. The more area that the ring covers, the higher the boost.
  6. 25(2)+2
    18,756
    45,806
    Sep 18, 2006
    the road less travelled
    This was called variable geometry turbo-charging, it is a way to bring up boost more quickly when the throttle is opened. I've driven them and they work, anything that makes for more complexity would mean more repairs down the road, I don't know that Cat or Cummins are any better, only way around the newer technology is to buy a crate motor that is no longer manufactured or go with a re-man or rebuild. I think you could still get a N-14 this way if you really have to have one.
    AJ
  7. drvovo
    drvovo Bobtail Member
    8
    Washington
    Volvo just started using them this last year on the new D11, D13 & D16 liter engines. Cummins ISX has been using it for years also. All that I have came across are manufactured by Holset. There was a recall for the D16 to change the actuator from a Delphi to a Holset. Other than that, they are pretty reliable thus far. They just need to be on the road a touch longer to give a long term analysis of reliability.
