Vcads that run off windows 7?
Discussion in 'Volvo Forum' started by 4play, Sep 6, 2015.
  1. 4play
    4play Light Load Member
    90
    12
    Nov 11, 2011
    Edmonton
    I've been look around with no luck, any ideas?
  3. M&KMIKE
    M&KMIKE Bobtail Member
    30
    20
    Jul 27, 2015
    The stand alone VCADS program is obsolete, and is no longer supported by Volvo. The new version of the Volvo diagnostic program is called Premium Tech Tool, and is now actually a version 2.0, or PTT2, as we call it. It is designed for use on the Windows 7 platform.
    You can find more information or place an order here:
    http://www.premiumtechtool.com/
  4. 4play
    90
    12
    Nov 11, 2011
    Edmonton
    Looks complicated and expensive
  5. M&KMIKE
    30
    20
    Jul 27, 2015
    That depends on how much you're going to use it. If you only have one truck, you're better off just taking it to someone who has it, or reading your codes through the dash. If you have a shop or a fleet, it's worth the investment.
    A really great alternative is Jpro. Lots of independent shops use it.
  6. 4play
    90
    12
    Nov 11, 2011
    Edmonton
  7. 4play
    90
    12
    Nov 11, 2011
    Edmonton
    What would be The best program through them for a 2012 volvo 780?
  8. M&KMIKE
    30
    20
    Jul 27, 2015
    Well the best would be PTT. What are you looking to do? Just read codes and diagnose? Change parameters?
    If you're only looking to read codes and do some light diagnosis, Jpro might be better. It works with all makes and models, and supports Volvo and Cummins engines (as well as other manufacturers).
    PTT only supports Volvo, and reads generic codes from non Volvo equipment (ABS, transmission, etc) with no diagnostics for non Volvo components.
  9. 4play
    90
    12
    Nov 11, 2011
    Edmonton
    I was hoping to beable to to the same as the techs at volvo do, including updates
  10. M&KMIKE
    30
    20
    Jul 27, 2015
    The only way to do that is to obtain a PTT client ID (basically a registration key) illegally (which has happened).
    Even if you buy PTT from Volvo, its a customer version, and does not allow module programming, and limited parameter changes. For example, injector trim codes cannot be programmed using the customer version.
    For software updates, you're better off just taking it to the dealer. It's a simple process, but do you really want to chance making a mistake and bricking your engine ecu?
    Medysa79 Thanks this.
