vehicle weights
Discussion in 'Questions From New Drivers' started by mjnkjn, Aug 6, 2009.
Page 1 of 4
I Might BE Wrong But I think It's 12,000 On The Steers And 33,000 On The TAndem And rears
34,000 on drives, 34,000 on tandem trailer axles, 20,000 each axle on a spread axle trailer...steer weights vary by state but in general they are around 12,500 or so.
Ok thanks for the help. and you can move that weight on the steers and drives by moving your tandems correct??
NO...you can shift the weight on the steers and drives by sliding the fifth wheel.
You can shift weight between the drives and the trailer tandems by sliding the trailer tandems. -
When shifting weight to the steer axle, make sure you do not put more weight on the axle than your door panel says the spec limit is, and the size and load range of your tires say they are rated for. Fussy scale masters may check!
FunkRider Thanks this. -
i thought it was 20,000 steers 34,000 drives 34,000 tandems
for a maximum 80,000 pound load, 34,000+34,000+12,000=80,000.
Page 1 of 4
