Vehicles to pull freight
Discussion in 'Questions From New Drivers' started by Mcjweb1, Mar 14, 2018.
  1. Mcjweb1
    Mcjweb1 Bobtail Member
    7
    Jan 13, 2018
    Can anyone tell me if you can use a 1 ton or larger Van to pull a trailer to haul freight instead of a pickup. thanks jlweb55
  3. Tron
    Tron Bobtail Member
    22
    24
    Jun 22, 2013
    You can pull any trailer with whatever power unit you like, but only if it is legal in terms of GCWR and all the rest of the regulations, like DOT,FMCSA, state length regulations, etc.
    .I suspect you are going to want a more expansive answer, but for that, you are going to need to know the specifics of the van, trailer, and freight that you are pulling.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    Simply need to find the ratings on the van and see if it can pull the weight required.
    Remember the van weighs more, so less product can be pulled. Even then most vans are made with engines, transmissions, and (most important) rear ends that are not designed with towing in mind.
    Tht said, if the weights of what you want to tow are good, go for it!
  5. Colt6920
    Colt6920 Light Load Member
    177
    260
    Apr 28, 2017
    Main issue I see is that a van is bumper pull only, which will significantly lower your max payload. Main benefit to a dually pickup is the ability to use a gooseneck and fifth wheel.
    Tb0n3 Thanks this.
  6. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    UPS package delivery vans [in rural areas and with unusual package counts] do this all the time.
  7. ZVar
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    Seen plenty of hitches one can put on a van. Doesn't need to be bumper only.
    As an example of one... 2017 Ford Transit T150 Trailer Hitch | etrailer.com
  8. GreenPete359
    GreenPete359 Road Train Member
    2,152
    5,101
    Oct 21, 2017
    Driving my recliner
    Jarrod on Shipping Wars alsays used vans. And you can put a hitch on a van so it can tow just as much a pick up can
