Very annoying noise..
Discussion in 'International Forum' started by TruckerPete1990, Jan 7, 2018.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,377
    Jul 16, 2012
    Bentonville Arkansas
    I got a 07 INT 9400... After about 45+MPH there is a noise it sounds like someone is pulling plastic wrap tight and blowing on it... The sound doesn't get worse if i hit the gas. It doesn't get worse if i let off the gas... If gets really soft under 45 to where u can't really hear it.. I use to only hear it on a windy day but now im hearing it all the time. Has anyone else had this problem Where to start as i don't think its an boost/exhaust leak....
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    CK your rubber boots on intake for a tear or bad clamp?
  4. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    Sense it wind speed related check your door/window seals.
  5. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
  6. TruckerPete1990
    8,623
    5,377
    Jul 16, 2012
    sprayed them all no bubbles. But wouldn't that adjust with throttle? This stays the same if i let off throttle or not lol
  7. mitrucker
    mitrucker Road Train Member
    5,259
    9,307
    Dec 15, 2010
    Lapeer, MI
    Sounds like wind noise from windshield or doors
    magoo68 Thanks this.
  8. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    If you have A old log/book page shut the door with it between door and rubber seal to see if it moves any place on down the door seal if you find a place it moves black tape or sealing tape will keep cold out an may quite it up??
  9. TruckerPete1990
    8,623
    5,377
    Jul 16, 2012
    Im thinking its windshield? Today while it snowed i was doing 65.. I Didn't hear the noise at all. Once it all melted it came right back lol
  10. pushbroom
    pushbroom Road Train Member
    1,779
    7,312
    Sep 1, 2012
    Tape around the outside of the windsheild to eliminate the seal
  11. Hammer166
    7,458
    27,031
    Aug 18, 2007
    ~8600+' and loving it!
    It's a Binder. Ain't nobody got a radio loud enough for that! :)
    Justrucking2 and lilillill Thank this.
