Vibratech damper install on a Cat 'C' and C-15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigguns, May 30, 2016.
  1. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    My new damper came with an additional plate. Does this plate go between the damper and pulley? What is the reason for the plate? Thanks Dan
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    I have seen some dampers that have a plate like that, maybe a 1/16" thick. They were directly under the bolt heads and work as a lock. I wound consult the mfg. Or use locktite, or go back as it was and use locktite, check the thicknesses. Don't want the bolts to bottom out because something is thinner.
    bigguns Thanks this.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    If your taking about the ring with the bolt holes in it, it goes on last before you stick the bolts in.
    Diesel Dave and bigguns Thank this.
