Vibration @ 55mph and above w/creek sounds at all speeds.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by femalecdla, Aug 3, 2024.
  1. femalecdla
    femalecdla Light Load Member
    172
    242
    Jan 3, 2018
    So I purchased a 2020 International LT 2 days ago. I did do a test drive and had the truck inspected. No major issues were found. Truck has a clean history with no accident reports. The problem was that I couldn’t test the truck at speeds greater than 55 mph because the cops were writing tickets everywhere. So, I didn’t notice the issue until I was able to increase my speed up to 70 MPH.
    I noticed a creeking noise like the truck needed a grease job and the joints were dry as a bone. It’s sounds like bad shocks/springs. I don’t know how to explain it properly.
    I also noticed that once I hit 55 MPH, it very bad vibration starts. I can feel it in the steering wheel, in the pedals and everything shakes. The vibration doesn’t go away until I’m below 55 MPH.
    The brake pedal feels like I’m pushing against a brick wall. I brought this up to the seller and I was told, “I’m just not use to the truck yet, they took the truck out and didn’t notice anything I mentioned.””
    So I took the truck to Love’s for a grease job and wheel balance. They told me there was no weight on one steer tire. Their balancer wasn’t working so they sent me to another shop they recommended.
    The tire guy said that my kingpin, bushing and bearings were shot and that I needed a new rim. He balanced the steers and told me he added weights to both steers. I wanted second opinion so I took it to another Love’s and they said my kingpins, bushing, and bearings were good. They said my rims were good also. They said I need a new steer tire. My steer tires look brand new with no cupping and no wearing on them. One tire is out of balance by 8oz and he recommended centramatics. I purchased them and still have very bad vibration. The dealership wants $4,000 for new bushings, bearings and labor charges.
    I’m no diesel mechanic and I know next to nothing about repairing semi trucks. I can do some work, but major work like this I cannot. I’m at a loss except to take it to the dealership. Could a fairly new steer tire be the cause of this? All shocks are brand new. There is no pulling to right or left, just creeking sounds and vibration above 55 MPH.
  3. MRMTRANS
    MRMTRANS Medium Load Member
    370
    402
    Apr 28, 2015
    I'd take it to MD Alignment in Altoona, IA. Mike Becket is an absolute expert at figuring out vibrations. I think they still do service, but may only be in the business of selling alignment equipment, training, and consulting. If not, there are "MD Alignment shops" across the country-businesses that were trained by Becket. My first guess to your vibration would be out of round radial circumference tire(s), with a slight tow out.
  4. MRMTRANS
    370
    402
    Apr 28, 2015
    I should have said, a good shop will have a radial runout guage. That checks how close to perfect circumference. I remember Becket saying on the radio that there is a point where no amount of weight in balance-whether weights, beads, Centramtics, or Balance Masters-with overcome a tire too out if round. You can check kingpins yourself probably cheaper than a shop would charge, even after buying a 20 ton jack and a tire iron. Just jack up the front wheel you checking, and take a tire iron with a socket on it and leverage the wheel up from under the tire. If there is play, then they are getting worn out. If you do that, then also buy a grease gun and lube the zerks while the front end is jacked and turn the steering wheel as far as will go a couple of times. That's how kingpins should be lubed, but its hardly done that way.
  5. RockinChair
    RockinChair Road Train Member
    5,136
    12,988
    Feb 19, 2012
    CC, TX
    It's possible that one of the tires could have broken or shifted belts.
    201 Thanks this.
  6. 201
    201 Road Train Member
    12,431
    25,426
    Apr 16, 2014
    high plains colorado
    Just because a tire looks okay, like ^^^, it could have a broken belt. On a 4 year old truck, it's unlikely any real wear, such as bearings, U-joints, harmonic balancer, steering or any other typical wear from an older truck, so by process of elimination, it has to be tires. I know, welcome to the game, IH is a good truck, and you'll get it sorted out, hopefully before you go nuts. Kind of a rule of thumb, if the steering wheel shakes, it's usually up front. If it shakes your rear end in the seat, it's probably from the back. Good luck.
  7. femalecdla
    172
    242
    Jan 3, 2018
    Thanks everyone. I will go back to love’s and have them replace my steer tires. I pray that that is the cause so I can get back on the road without worrying that my truck is about to fall apart.
    blairandgretchen Thanks this.
  8. 201
    12,431
    25,426
    Apr 16, 2014
    Don't worry, your truck won't fall apart, although it may seem like it might. Trucks are tough and you'll get it right. Be cautious about simply "replacing" parts without good cause. I know, it's a bit of a crap shoot, and like many say, start at the front and work back, which can be costly. Tires are about the most costly item, as you can buy new steer tires, and run over a bolt, ta-da, trailer tire, and you can't be bummed about that. It's the cost of trucking. Be glad it's only the tires these here days. Not sure where the creaking sound is from, typically a dry 5th wheel or spring hangers, but again, the truck isn't that old for front end wear,,,yet.
    OlegMel Thanks this.
  9. Ridgeline
    22,453
    117,517
    Why?
    You are going to waste money on guessing on what the problems are.
    Do it right first, take the time to get it into a real shop, not Loves or T/A, those are oil change places. Take it to an MD shop or the dealer.
    With worn Kingpins, there is a chance that this is a problem that adds to it, so stop throwing money at the problem hoping it will go away.
    Cenramatics?
    I have a 50/50 bit of luck with them, I may have a few sets sitting in the corner of the shop, removed from trucks that could not use them because they didn't work.
    Getting an inspection means having a mechanic actually inspecting the truck, not a DOT inspection. It may not be you but I don't get how owners think that the DOT inspection is one that is good enough for a purchase, that is stupid - yes I said it. An inspection I get is paid to find things that are wrong, seriously and trivially wrong, that inspection findings goes right into the negotiation for the truck, if it needed kingpins, then $2k is taken from the offer, if it needs tires, then $1000 and so on. The inspection means things like the king pins are checked, it means that the oil is removed from each major component to check whats going on.
  10. RockinChair
    5,136
    12,988
    Feb 19, 2012
    CC, TX
    To save yourself some time and potentially a lot of money, I'd take it to a reputable tire shop (not a truck stop) and have them put both of the steers on their balancing machine. Each one needs to balance out to zero before it goes back on your truck.
    Then, give your truck a good greasing. Replace any zerk that won't take grease or that spits grease back out after you remove the grease gun.
    Once you've done those two things, if the vibration still persists then you can begin looking at things like the alignment or worn components.
    But it's best to get rid of the easy, obvious, and relatively inexpensive things first.
  11. Tropsnart
    Tropsnart Road Train Member
    1,130
    2,384
    Jun 8, 2015
    Pavilion New York
    Check your air pressure in all of your tires. Look closely at your steer tires at the point where they contact the rim.
    Visually inspect them for flat spots . If your truck was sitting at the place you bought it from for quite a while, then your tires may be squared off where they contacted the ground. If they are an off brand tire get rid of them.
    Check your ride height, if it's off it can cause vibrations.
