Violent Shake When Using Engine Brake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by hawkjr, Jul 31, 2018.
  1. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    I get a real bad shake when my Jake's engage within the first 5 seconds or so...I can disengage and reenage and it's fine for the first 3-5 seconds then it goes back to the shaking.. Anybody got a clue? The truck is a 2014 T660 with a Cummins
  3. line
    line Medium Load Member
    388
    439
    Dec 28, 2017
    I had a Cummins also , the oil runs high temp. Like sixty degrees over a Cat. If you’re using thin oil like a 40 weight synthetic it’ll wear out the parts faster . Plus I always had problems after over heads . Is it a two stage or three .? Does it shake the same in all stages ? Pull the valve cover off and run the jakes manually . You likely have a few bad jake rockers or oil leaking into your solenoids . Run thicker oil and use an additive like MotorKote
  4. hawkjr
    1,652
    638
    Feb 28, 2010
    Virginia
    All 3... It seems when the truck is cold it doesn't do it until it warms up so that could be it
    line Thanks this.
  5. Ridgeline
    22,649
    120,869
    Run it into the shop and have them do an overhead and check out the system.
    hawkjr and line Thank this.
  6. line
    388
    439
    Dec 28, 2017
    Aye . Especially in warm weather when the oil thins . Use a fifty weight and motorkote, You’ll notice a big difference even in your fuel mileage
    hawkjr Thanks this.
  7. Lone Wolf 0811
    Lone Wolf 0811 Bobtail Member
    What was the outcome??
